Hi. Just recently got my 1999 328i. It drives awesome and has TONS of power. However, my engine makes a noise that sounds like two pieces of metal rubbing each other at all rpm. This noise is very regular. Like I say - it is strong and all, and shows no other signs of trouble but continously makes that noise. It is a bit louder when cold. I have 55k on this engine.
My specific questions are: IF YOU KNOW WHAT IT MIGHT BE:
1) Can I just keep on driving it and I should be OK?
2) Should I take immediate action to correct it?
I used to have a 1993 Nissan Altima which made exact same noise when cold at low rpm only - I put on about 15k (with this noise) miles on it and it never showed sign of additional trouble. Please, help!
Hmmmmm sounds like a bad pulley..... Get it fixed now otherwise later your belts gonna go along with the rest of the engine... Don't be cheap a pulley is only $50 and the belt cost me $28
Sure you can. But if the pulley fails, the belt goes with it, your alternator goes out, and the car overheats... Basically what you could have fixed for $100+ will turn into a $1000+ problem (Yes grab your ankles and pull out the vaseline.... well actually no vaseline... nevermind)...
It's up to you.... It just so happenned my mechanic heard it (bad pulley) from a mile away and I got lucky... If this happenned later down the line I would be picking up E46 parts off of the freeway.
__________________ General, Troll Warfare Center: Task Force Troll/Founder BMW FORUMS 3.1415926535897932384626433832795 CLUB/Board Member Brotherhood of Huzzah/Board Member Troll Assassin Board/Board Member W00t! Club/Campaign Director Yanosh for President/Founder L337 Flash Club/Founding Member BMW Forums V1 Club/ BMW-Forums Badger Badger Badger arrgggghhhhhh club
Thanks for your input.... I get the feeling the noise is actually coming from the inside of the engine, more like valve cover area... ? Is that possible?
it may be camshaft. i have that noise in my 93 altima as well when it is cold. not sure if the BMW uses the same deal
__________________ Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
Oh yeah may also be improper tension on the belt that may have caused a shot pulley.... I dunno I'm no expert.... But that's what happenned to me.
sounds like several possibilities. I'd check the waterpump and both belt tensioner pulleys. These are most common.
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
Allright... what if it is a water pump or a pulley? How do I actually check on this? The area between the pulleys and the radiator is so crammed there is no way to stick a finger in there! I have no leaks or anything.
