12 Faulty Codes - BMW Forum - BimmerWerkz.com
Old 01-21-2005, 10:12 PM   #1 (permalink)
bigbpappa is an unknown quantity at this point
My SES light came on a few days ago, again. It had been coming on and off causing a hard idle but then would go away when i would restart it for about a year now. Took it to the dealer but they said they couldnt find anything wrong. Hadn't happend for about 4 months until now. However, now it wont go away.
Basically, the car idles rough now. I went to autozone and got an OBD read which indicated 12 errors! First, it said there was a faulty oxygen sensor. Then the next 9 errors had to do with random misfirings from all sorts of cylinders. The last two errors said something about a about the fuel, I think it was the Fuel Air Metering error or something.
Could all these errors have been caused by faulty O2 sensors or what? My car is under extended warranty with 71 k and a 2000 323ci.
bigbpappa is offline   Reply With Quote
Old 01-22-2005, 12:41 AM   #2 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
Under Warranty.. I'd bring it back to the dealer.. maybe another one, and ask them to check it out again, tell them what you found out on your own. Just my opinion, I'm not a mechanic. You could invest in your own reader for i think it's under $150 from Peake Research. Just so you know and won't have to go to autozone for thier help. Just an idea.
Dough
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
Old 01-22-2005, 12:53 PM   #3 (permalink)
storme's Avatar
storme is an unknown quantity at this point
squirt some carb cleaner up the air filter box,,with the filter removed...
i know you have no carb,,but it will cleaner out the air flap from the air metering sensor
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 01-23-2005, 12:53 PM   #4 (permalink)
jesse91911 is an unknown quantity at this point
I had the same thing happen to me just last week to my 2000 328i. I had fault codes reading o2 sensor adaption limit and control limit. Also all cylinders were missfiring. Car was running extremly rough at idle and missfiring. To make a long story short it was a vacum leak that was causing the problem. It was the crankcase vacum valve that went out. Only cost about 50$ to replace. This part has a rubber diaphram and it went out. The way I tested it was I sprayed carb cleaner on all of the vacum lines to check for leaks and eventuly I sprayed the front hose that connects to the crank case under the intake manifold and the car started to run normal again. Hope this helps. Jesse
jesse91911 is offline   Reply With Quote
Codes P1421, P0420, P0430 Larry Horne 3-Series (E36) 2 10-17-2005 09:06 PM
Obd1 Fault Codes, Help! toast_mcmann 3-Series (E36) 10 08-01-2005 10:08 PM
Codes MichelVaillant 5-Series (E12,E28, E34, E39, E60) 4 05-10-2005 11:55 PM
