So I’m not 100% sure what option to go with to upgrade the stereo system in my
2006 325Ci E46 Coupe.
Factory features: SAT NAV wide screen, Tv, reverse camera (currently not working), Bluetooth mobile phone connection with steering wheel controls
I want to be able to play songs and watch vid clips and/or movies from a usb stick.
Thinking at this stage the “Dice Mediabridge MB1500” retailing on ebay for around $540 (pic#1)
eBay Australia: Buy new & used fashion, electronics & home d?r
I want to be able to put my music on a usb stick and play it through my original head unit with song details appearing on screen, (if possible)
Also if I can not find a reasonable priced solution to my reverse camera issue, this unit should also accommodate an aftermarket OEM cam.
Can I achieve my goal with a cheaper alternative? (including vid clips, etc)
Anyone done so or is this mediabridge the one?
Moving onto the hardware of the sound sytem:
I’m thinking I will need the “PAC SOEM-4, Universal 4-channel line output converter” ($70) (pic#2)
http://www.ebay.com.au/itm/280489083...84.m1436.l2649
To hook a:
Boss PH4.600 4-Channel MOSFET POWER Amplifier 2400W Car Amp
($185) (pic#3)
http://www.ebay.com.au/itm/190648013...84.m1436.l2649
To Feed a:
Alpine S 12” Sub installed in a custom area typical to this,
($200) (pic#4)
http://www.ebay.com.au/itm/280418851...84.m1436.l2649
Then swap: the rear speakers out for something like this:
BMW 3 Series Front or Rear Door 13cm 2 Way 210 Watts Car Speaker Fitting Kit ($130) (pic#5)
http://www.ebay.com.au/itm/400304152...84.m1438.l2649
**A set of 6” splits in the front and maybe in the rear instead of previous option (2ways)**
These will be attached to these:
BMW 3 Series E46 Front or Rear 165mm Car Speaker Adaptor Plate
($40) (pic#6)
http://cgi.ebay.com.au/ws/eBayISAPI....vip=true&rt=nc
Is there a better way to achieve what I’m hoping with different modules etc.??
PLEASE HELP I VALUE EXPERIENCE AND OBJECTIVE OUTLOOKS.
