03' 330ci Spt Pkg. Tires..help!! - BMW Forum - BimmerWerkz.com
Old 12-04-2004, 07:37 PM   #1 (permalink)
BMWCOP is an unknown quantity at this point
[attachmentid=15836]with winter comming close here in n.y.c.... was lookin to get studded sno tires.... question is......
orig eqip. is front tires different then the rear tires....(in size)
would the front tires fit on the rear with no problems, b/c they only have that size to fit.(studded) http://www.vulcantire.com/ggrip2s_s.htm
any comments will be very helpful.. thanks!
Only cop in n.y.c to let the bimmers go free!!!
BMWCOP is offline   Reply With Quote
Old 12-05-2004, 11:12 AM   #2 (permalink)
330 i will take 17 inch rims, not 16 (will not fit over calipers). steel wheels with correct offset avaliable at bavauto for about $80. 325 will take 16.
for 17 inch 205/50 size will fit on all corners (size difference less than 1%, and will not trigger dsc or abs). i bought semperit sport grip($88) which is studdable, but check local laws some will not let u use steel studs.
Old 12-05-2004, 12:57 PM   #3 (permalink)
[snapback]243865[/snapback]
i have 17's, also, do you have the same type of set up? spt pkg 330ci? 03? i see u bought semiperit's..... how were they in the snow? thanks for you help...ill check the laws also. love winter, but not in the 3 series...its like one big ice skate!
Old 12-05-2004, 05:30 PM   #4 (permalink)
no mine is a 330 perf pack, which comes with 18 inch rims, 225/40 front 255/35 rear.
no snow yet in baltimore. they all work well....
18" option tires on 330Ci youngn3 3-Series (E46, E90) 3 06-23-2004 10:25 PM
330CI WITH TIRES 255/40/17 SERGEY1 3-Series (E46, E90) 1 06-16-2004 08:53 AM
330CI Tires and Rims bmwnetgui 3-Series (E46, E90) 1 05-28-2004 02:12 PM
