03 325i Steptronic Problem - BMW Forum - BimmerWerkz.com
Old 01-30-2004, 11:04 AM   #1 (permalink)
bigslick175 is an unknown quantity at this point
I have a 2003 325i with a malfunctioning Steptronic in cold weather. When the car is cold in the morning and is placed in drive, there is very significant slippage in the transmission. Has anyone else had the same problem? How do I address this problem?
bigslick175 is offline   Reply With Quote
Old 01-30-2004, 12:01 PM   #2 (permalink)
BMWPro77's Avatar
BMWPro77 is an unknown quantity at this point
Send a message via AIM to BMWPro77
Talking
It's not the transmission. It's the new clutchpacks they've been putting in the 2004's. They're now using a 5 puck clutchpack versus the 7 puck clutch packs they've used in previous years. The 5 puck pack engages slower which causes the delay in gear engagement. The 5 puck pack isn't as powerful as the 7 puck. Consult your service department. This issue is known by BMW and is slowly being rectified. I'm not sure what the ultimate result is gonna be but they replaced one for a customer of mine with the old setup. It's probably on a case by case basis.
<a href='http://members.cardomain.com/Nutchingbutagti' target='_blank'>My '99 323is Home!</a>
<img src='http://images.cardomain.com/member_images/5/web/305000-305999/305054_17_full.jpg' border='0' alt='user posted image' />
<span style='font-size:21pt;line-height:100%'>&lt;span style='font-size:14pt;line-height:100%'&gt;BMWPro77</span>&lt;/span&gt;
BMWPro77 is offline   Reply With Quote
Old 01-31-2004, 07:13 PM   #3 (permalink)
TECH's Avatar
HUH?
Actually, the 03 GM transmissions used by BMW have "unfavorable tolerances of C1 clutch housing causing internal trans pressure leak after extended parking". So, the fluid drains out after sitting, and when you put it in driver, it takes a while to build pressure and engage.
BMW is replacing these transmissions. Make an appointment with the dealer, so you can get on the list for a new transmission....
we are doing a LOT of them, and new trannys may be slow in coming.
There is a service bulletin for this. The symptoms are a delay in transmission engagement to drive, on cold start.
Applies to:
E46 with GM5 9/02-12/03 or 3/03-12/03
depending on the model car.
325i white smoke and idle problem puppie 3-Series (E36) 3 10-22-2005 07:57 AM
E36 325i problem with power steering after doing doughnuts!?!? anar_325i 3-Series (E36) 10 10-12-2005 05:18 PM
93 325i Conv. Starting Problem JasonGrant 3-Series (E36) 3 03-17-2005 10:15 AM
325i stalling problem bethbdm 3-Series (E36) 11 05-30-2004 10:25 AM
325i starting problem paul g 3-Series (E36) 10 01-05-2004 09:17 PM
