'02 won't start.. - BMW Forum - BimmerWerkz.com
Old 04-01-2008, 12:42 PM   #1 (permalink)
Car: 2002 BMW 325xi
Schreiner_d is on a distinguished road
Question '02 won't start..
Hello all -- I just joined the site -- and I could use a little help...
I have a '02 325xi that won’t start. I was able to jump start it and drive it home. While driving home – the dashboard warning lights would periodically flash on and off (ABS, traction control, emergency break, check engine lights). The next day, I tried to jump it again, but it wouldn’t start. The dashboard illuminated and the radio and headlights came on, but the starter solenoid only ‘clicked’. I checked the battery, and the battery indicator was black (indicating that the battery was in good condition). Also the battery connections were tight and not corroded. Where should I check next? I assume that I have a loose connection somewhere since the jump start wouldn’t work. Could it be the battery ground wire? Whats the easiest way to get to the starter to check that connection?
Thanks in advance!
Schreiner_d is offline   Reply With Quote
Old 04-01-2008, 03:30 PM   #2 (permalink)
zibby's Avatar
Car: yes
That what you experienced(flashing dashboard lights, clicking sound, etc.)mean you battery is gone.It is time for new one.Black indicator=baterry needs to be serviced.Green indicator=battery is OK!
http://www.q8oils.it/
Old 04-01-2008, 08:53 PM   #3 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
check voltage on the battery it is most likely dead....
1992 318i Coupe parts car
I am Captain Obvious
Non Start / Cold Start chigs 3-Series (E46, E90) 0 01-31-2008 04:49 AM
want to start off right andyo Wash & Detail 2 10-08-2007 07:48 PM
Hard Start Becomes No Start 325eXTATIC 3-Series (E21, E30) 3 05-20-2005 05:30 AM
no start slinkyjoe311 3-Series (E36) 8 09-11-2004 01:06 PM
start off a new B3M2W5i 3-Series (E36) 10 08-30-2004 11:46 AM
