01 330ci help please - BMW Forum - BimmerWerkz.com
Old 11-12-2009, 06:36 PM   #1 (permalink)
vancem3m3 is on a distinguished road
First, let me say hello to everyone since this is my first post! Ok, heres the deal with my 2001 330i... My SES light came on so I checked the code, it was a P0335, crankshaft position sensor. I ordered the part from the dealer and had it replaced. Unfortunately it didn't fix anything. The code came right back. So, I've made an appointment to have the dealership work out the problem, but I'd like to be armed with some ideas before I go.
Heres the symptoms: SES light on, DSC light on, car has no power and shudders as if it's fuel pump or injectors are not working properly at RPM ranges higher than 2500.
I wouldn't be worried but the only code it's throwing is the P0335, since I've already replaced that and it didn't solve the problem I don't know what to do next.
I did search through the forums (this one and a couple others) and found a lot of post reguarding this, however none of them covered the problems I'm having with mine.
I don't think the sensor they sent me would be bad, so can anyone think of another that code would come up aside from the sensor?
Thanks for any ideas!
vancem3m3 is offline   Reply With Quote
Old 11-19-2009, 08:04 AM   #2 (permalink)
Do you know if you are getting the correct fuel pressure at the fuel rail? It is possible that the fuel pump or fuel pressure regulator is malfunctioning and the car thinks it is the RPM sensor.
The only other thing I could think of would be an issue in the wiring for the sensor.
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Help With My New 330ci DerCarFreak 3-Series (E46, E90) 6 05-13-2005 02:51 PM
Im Getting A 330ci 4-6motoring 3-Series (E46, E90) 1 11-06-2004 09:36 PM
330CI or 330CI CAB??? 2 Beeg 3-Series (E46, E90) 0 05-06-2004 11:00 PM
TC for 330ci Anomaly460 3-Series (E46, E90) 1 04-14-2004 02:17 PM
330ci Anarchy'sBMW 3-Series (E46, E90) 8 10-26-2003 09:45 PM
