Winter/spring project - BMW Forum - BimmerWerkz.com
Old 11-28-2005, 10:45 AM   #1 (permalink)
theironm0nk is an unknown quantity at this point
Now that I have gotten everyone x-mas presents I can start getting money to repair my car. I officially decided to keep my car because I raced a 328i and kept up with it even in its bad condition. I have found what I want the exterior to look like(posted below)
UUC stage 3 suspension
x-brace
TMS zimmerman brake kit W/ SSB brake lines
UUC SSK W/ ERK
Dinan chip
subframe reenforcment
17 inch e46 M3 rims
UUC rear spoiler
bavauto high performance coil kit
Depo 36 projectors w/ DDE
xenon interior lights
M3 steering wheel
Dinan highflow throttle body
Winter/spring project-m3-custom.jpg
theironm0nk is offline   Reply With Quote
Old 11-28-2005, 12:21 PM   #2 (permalink)
quality
Delmarco's Avatar
what car do you have...a 325 or 318?
Old 11-28-2005, 12:31 PM   #3 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Those e46 M3 fender vents dont belong on a e36.
Good Luck and keep postin pics of the project!
Old 11-28-2005, 08:54 PM   #4 (permalink)
Storamin's Avatar
Storamin is an unknown quantity at this point
with the sidemarker, i think the vents bring it over the top. without the sidemarker, i think the vents look fine.
Storamin is offline   Reply With Quote
Old 11-28-2005, 09:19 PM   #5 (permalink)
ex owner/admin
Furious's Avatar
he has a 318 with 200hp, against a 328 you should smoke it, M3's only put down around 200-210hp, the car above looks good except the vents and im not a huge fan of those style M3 wheels
Old 11-28-2005, 11:27 PM   #6 (permalink)
actually I'm gonna black out the vents because its on a granite silver(gun metal grey) I have no side markers
http://jlevistreetwerks.com/OSCOMMER...c73570294bc893
My car needs alot of work fuel pump is goin bad. The funny thing is that with all the broblems I have it still doesn't equal to an amount that makes it more worth getting a newer BMW
M3 have 240hp
Old 11-28-2005, 11:43 PM   #7 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Just curious, how on earth does one get 200 hp out of a 318 without supercharging it?
Lindsay fan club member.
Old 11-29-2005, 12:27 AM   #8 (permalink)
a 318is has about 135HP an engine balance gives it about 50HP then a port and polish adds about 25-30HP. When I first got my BMW it needed a tune up so some HP was lost when I had it dyno
When fully working it should have about 210HP then add a chip +11 then a high flow throttle +6 New exhaust +8 you get about 235hp
Old 11-29-2005, 01:12 AM   #9 (permalink)
ex owner/admin
Furious's Avatar
no, sorry to burst your bubble monk , there is no way your gonna get those numbers from a 1.8 4 cylinder,first off without a proper dyno done, i cant believe 200hp, you cant guesstimate crank HP you need to see what your wheel HP is. get a good dyno run in (one run is relatively cheap) so at least you know what your working with before you put the mods on.
the second thing is the bolt on mods you described above will probably not give you anything close to a combined 25+whp, maybe closer to around 13-14 at the most.
im not saying your wrong , i very well could be, but i know that even a supercharger for a 318 barely gets 190whp, horses to the crank and to the wheels are two totally different things, by your calculations your saying your car with a balanced and port and polished 1.8 is faster or should be faster than a 3.2 M3 (240hp to the crank , around 200-205 to the wheels)
i think you need to throw that baby on the dyno again and post up some before and after charts when you bolt on the mods.
Old 11-29-2005, 10:05 AM   #10 (permalink)
Teh Prof's Avatar
OK, I'm no Click and Clack here, but this sounds a little wild to me. First off, please fill me in on what you mean by an engine balance and how it adds such a huge amount of HP (and how I can do it on my M3!!!). Secondly, those numbers seem kinda high for a port and polish on a 1.8L engine.
Old 11-29-2005, 11:04 AM   #11 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
I think someone has been playing a little too much gran turismo 3
Old 11-29-2005, 03:35 PM   #12 (permalink)
Tochenzo's Avatar
Tochenzo is an unknown quantity at this point
Send a message via AIM to Tochenzo
what kind of eyebrows do you have on that car? And where'd you get theM?
Tony
National Capital Chapter BMW CCA #367673
1998 Hellrot 328i
Tochenzo is offline   Reply With Quote
Old 11-29-2005, 03:44 PM   #13 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
yea 200 whp on a 318 is something ive only seen on supercharged ones..there is a guy on bimmerforums who has a SC 318 whos is pushing like 190 to the wheels...
i think i should go get a port and polish and balance..ill be running like 250
as far as mod gains...ur lookin at 0-3 for exhuast, 11 is abuot right for the software and about 3-5 for the throttle body
Old 11-29-2005, 09:38 PM   #14 (permalink)
http://www.maintenanceresources.com/...inebalance.htm
I used the dinan charts for numbers.
Old 11-29-2005, 10:46 PM   #15 (permalink)
Teh Prof's Avatar
I read the article. Intuitively, it makes quite a lot of sense for the purposes of engine longevity. I'm not sure how it could increase horsepower to the rather dramatic degree that you claimed. In addition, the article suggested that in order to be effective the procedure should be carried out weekly. If I wanted to spend that kind of money on a car, I think I would have bought a Murcielago. Where do you go to have your engine balanced in this way, anyway, and how much do they charge you each time you go?
About the Dinan numbers, keep in mind that differently sized engines respond to Dinan upgrades to varying degrees--usually based on engine size. Larger engines respond more to being able to breathe more freely. Surely one can only expect the Dinan-advertised gains for Dinan products on the larger 6 cylinder BMW creations rather than the smaller 1.8's and 2.0's?
English project Mortiorchis Picture Showroom 4 11-18-2005 07:10 PM
E21, Project Swap DJProfessor 3-Series (E21, E30) 80 10-18-2005 11:41 AM
1984 318i Resto Project... filter27e 3-Series (E21, E30) 4 07-23-2005 12:12 PM
My 1990 535i Project BILLKICKSASS 5-Series (E12,E28, E34, E39, E60) 0 10-12-2004 02:38 PM
I have the parts to start my project :) Zq-8_dawg 3-Series (E36) 9 09-23-2004 11:47 PM
