Window problems - BMW Forum - BimmerWerkz.com
Old 07-29-2004, 12:34 AM   #1 (permalink)
Kevin325i's Avatar
So the autocross is sunday. You'll need to know that
Today I installed my Dinan chip (yes it's sweet, blah blah blah go buy one) and I disconnected the battery. No I don't know why, the directions didn't tell me too I just did. So I hop in the car, bam it starts, zoom zoom etc.
It's a nice day out, so I go to put my window down. Only the driver's window doesn't work. Everything else does so it's not the CR.
When I press the button I hear the click if I press either way up or down. By click I mean it sounds like the actuator is doing something in the window itself. Just a switch or did disconnecting the battery fry the motor?
So I gotta fix this because if I can't get the window down, I can't race.
thanks
Kevin
Kevin (President TBEA)
Old 07-29-2004, 12:52 AM   #2 (permalink)
Black318IS is an unknown quantity at this point
i think that same thing happened to me. all i did was open and close the door until the window went all the way up
Black318IS is offline   Reply With Quote
Old 07-29-2004, 01:18 AM   #3 (permalink)
Kevin325i's Avatar
How'd you fix it? Right now I'm more worried about makin the window go down than I am about making it go back up.
Also, the sedans have the windows that don't need to go up and down to seal because they're is a top part to the door (don' tknow how to describe it)
Kevin
Old 07-29-2004, 04:29 AM   #4 (permalink)
skawful's Avatar
skawful is an unknown quantity at this point
Send a message via AIM to skawful
q: why do you have to be able to unroll the window?
and also: can you get me a used dinan chip???
<img src='http://img259.imageshack.us/my.php?image=sig8hw.jpg' border='0' alt='user posted image' />
skawful is offline   Reply With Quote
Old 07-29-2004, 05:55 AM   #5 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
If it helps you any.... the steps for installing a Shark Injector ECU upgrade.... tells you to roll down the windows... I'm not at all knowledgable in the Dinan chip and how it works... but thats how it works for the Shark. Any correlation?
1997 E36 M3 1990 E30 325i
Old 07-29-2004, 12:22 PM   #6 (permalink)
Kevin325i's Avatar
well it doesn't say anywhere to even disconnect the battery in my directions. They have a hotline I'll probably give that a call if I can't sort this out quickly today.
Old 07-29-2004, 12:31 PM   #7 (permalink)
Kevin325i's Avatar
Ok, nevermind, I disconnected the battery again and everything works now. Thanks for the theories.
Old 07-29-2004, 08:55 PM   #8 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
How in the hell did you reprogram your ECU with your battery disconnected?
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
Old 07-29-2004, 08:55 PM   #9 (permalink)
Deloriant's Avatar
Ohhhhhhhhh, chip, not injection. All you chip whores!
Old 07-29-2004, 09:41 PM   #10 (permalink)
Kevin325i's Avatar
Bah obd II. If you didn't live in CA you could get away with the OBD I conversion, but I bet there's no way in hell you could pass emmisions with it.
Old 07-29-2004, 09:59 PM   #11 (permalink)
skawful's Avatar
i was gonna fuckin say to do this!
Window Problems 94325is 3-Series (E36) 5 08-17-2005 04:29 PM
Annoying Window Problems... d3ity 5-Series (E12,E28, E34, E39, E60) 0 12-02-2004 12:05 AM
window problems westy323is 3-Series (E36) 2 09-02-2004 05:25 AM
1995 BMW 525i window problems danutuc 5-Series (E12,E28, E34, E39, E60) 2 08-21-2004 11:58 PM
rear window problems whaleman 5-Series (E12,E28, E34, E39, E60) 6 08-22-2003 02:27 AM
