| Window problem I found out lately my window in the drivers side( Front L) was not mowing at all with switch on, opened up the front panel and found the motor is working well, turning the geras of the windoe regulator, also i found that the actuator arm (lifting mechanism of the window) is detached from the main frame of the regulator, so I presumed the problem was the actuator arm not being pushed up or down by the motor. My questions are;
1. Is the actuator arm part and one of the main regulator, is it detachable that it can be reconnected if things like this happen, or shall I buy a new window regulator.
2. The regulator is riveted to the metal panel, how can one remove it and how will you put it back without using rivets?
Any suggestion will be greatly appreciated, is there any DIY page or web that I can access? |
