Window Problem - BMW Forum - BimmerWerkz.com
Old 06-22-2006, 08:47 PM   #1 (permalink)
CiscoKid's Avatar
Window Problem
Well... i have power windows in my car, and when i roll it up, it becomes very slow at the top. It also begins to tip foward (towards the front of the car) slightly, but that can be corrected by pulling the window towards the back.
So... it did this before and the result was a broken window regulator (it bent and sheered off).
Now, i took out the weather stripping and put it back in... no dice, however there was no slowdown without weatherstripping. Any other suggestions?
Old 06-23-2006, 08:22 AM   #2 (permalink)
Gator is an unknown quantity at this point
It appears that the window has worked itself out of alignment. Consult the Bently Manual for instructions and realign window being careful to disable airbag.
Gator is offline   Reply With Quote
Old 06-23-2006, 09:44 AM   #3 (permalink)
Silicone spray ?
I have found that these window mechanisms need some spray lube applied over the years. You can try some spray silicone and see if that's enough, or you may need to pull the interior door panel and spray a heavier lube on the window track and running gear. These cars are ten or more years old now and the original lube is drying up.
Mike
Hamfisted is offline   Reply With Quote
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
window problem, at wits end erubin 3-Series (E36) 1 06-10-2006 07:54 AM
1992 E36 Drivers Window Problem whitey_no6 3-Series (E36) 1 06-08-2005 01:00 PM
Power Window Problem 123NotIt 3-Series (E36) 4 12-02-2004 02:02 PM
Power Window And Door Lock Problem...96 750il moabxj01 1,6,7,8 - Series and Mini Cooper 1 11-16-2004 03:30 PM
