Window Motor Replacement - BMW Forum - BimmerWerkz.com
Old 01-30-2005, 05:12 PM   #1 (permalink)
mostwired is an unknown quantity at this point
Thumbs down
I removed the door panel to replace window motor, and to my disappointment the motor and arm assembly is held on to the door by metal clips of some sort, and not by screws. How do I remove them?
I have a motor that doesn't "learn" the stop positions for the window, and keeps trying to raise / lower the window after it has reached the limit. I got another motor/arm assembly, but really need to replace just the motor.
If you have any tips, I'll appreciate much.
Here's a pic of the "clips" that hold the window assembly to the door.
mostwired is offline   Reply With Quote
Old 01-30-2005, 05:22 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Aight.. nevermind the PM I sent you...
To remove the motor.. first you need to remove the door panel which you have done.. then remove the door glass .....
Then remove the door handle...
Disconnect the wiring connector to the motor...
You then remove the regulator mounting bolts if it has them.. which yours does not.. since you have rivets.. you must drill them out.. you may replace them with bolts of the same size...
Then you remove the regulator assembly from the door...
Then unbolt the power window motor from the rear of the regulator...
As I said before... some of the regulators are mounted with rivets.. which is your problem.. you may replace them with M6 x 10 bolts.. and self locking nuts..
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Window Trouble Sporty540 5-Series (E12,E28, E34, E39, E60) 4 01-10-2005 11:49 PM
Power Window Problem 123NotIt 3-Series (E36) 4 12-02-2004 02:02 PM
Power Window And Door Lock Problem...96 750il moabxj01 1,6,7,8 - Series and Mini Cooper 1 11-16-2004 03:30 PM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 03:28 PM
Power window fun! kestrel325is 3-Series (E36) 7 07-17-2004 09:56 PM
