Will 19 Inch Rims Rub? - BMW Forum - BimmerWerkz.com
post #1 of 18 (permalink) Old 10-05-2004, 07:02 PM Thread Starter
Brian325i is an unknown quantity at this point
THinking about getting some 19 inch rims, I thought I remember hearing that 19 inch rims with 235/45/19 rims will rub on the wheel well if you take a turn too hard or if you go over a bump.
Brian325i is offline
post #2 of 18 (permalink) Old 10-05-2004, 07:22 PM
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
i dont know if there are any that low, but if u have 19's u will need to go much lower profile then 45..
are u sure these are for ur car, because if they are comin off of an e36 ur fine, if they are comin off like an x5 or something, check and make sure the bolt pattern is the same
xsperf is offline
post #3 of 18 (permalink) Old 10-05-2004, 07:22 PM
WOT in Reverse
jllphan's Avatar
jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute jllphan has a reputation beyond repute
18's will rub much less 19's.
If you want a big wheel, plan on rolling your fenders and replacing the springs and shocks with stiffer components.
jllphan is offline
post #4 of 18 (permalink) Old 10-06-2004, 12:18 AM Thread Starter
What wheel and tire setup do you use?
post #5 of 18 (permalink) Old 10-06-2004, 09:25 AM
sabbath130 is an unknown quantity at this point
[snapback]205758[/snapback]
i have a 1996 318is with 19'' axis hagen rims.. my tires are toyo proxies
225/35 ZR 19.. that is the reason i have NO rubbing watsoever
<a href='
border='0' src='http://x10.putfile.com/10/2840006249.jpg' alt='Hosted by Putfile.com'></a>
sabbath130 is offline
post #6 of 18 (permalink) Old 10-06-2004, 01:14 PM
ex owner/admin
Furious's Avatar
Quoted: 1 Post(s)
sabbath you need to drop the front end a bit. you got a bit of fender gap. drop it like an inch and half and that car will look tight brotha!
Furious is offline
post #7 of 18 (permalink) Old 10-06-2004, 01:21 PM
[snapback]206063[/snapback]
i wanna do it SOOO bad.. but i dont think that i can drop the back any further without causeing rub... so i am still contemplating my options. i AM gettin the S/C that autotecnica sells.. so that is something else i am waiting for. I expect that the S/C will add some weight to the front thus causeing less wheel gap in the front. so after i get the S/C in i can determine how much of a drop i actually need.
I expect to OWN the S/C in 3 months... and i expect to have it installed within a month after that.
<a href='
post #8 of 18 (permalink) Old 10-06-2004, 07:07 PM
-pimpin328is-'s Avatar
-pimpin328is- is an unknown quantity at this point
I have 18s on my car (225/40/18) and i have no problem at all with any sort of rubbing, in fact i have room to lower my car when i get the $$$ So if you don't want risk getting 19s because of rubbing issues or go through the trouble of additional mods just to fit the 19s then go wtih 18s, they look just as good to me
Mods: Tint, Euro Tails, Smoked corners and Side Markers, E46 Style Shadow Grill, 18&quot; M3 Replicas, M3 Exhaust, Low Beam Silver Stars
-pimpin328is- is offline
post #9 of 18 (permalink) Old 10-06-2004, 07:13 PM
WOT in Reverse
jllphan's Avatar
Seriously Sabbath, how do you get that ride height? My 17's sit a lot deeper. Wheels look great, but it could sit lower.
I guess I forgot to mention, it also depends on how you drive. I can make my 17's rub if I try hard enogh, and test my limits daily.
jllphan is offline
post #10 of 18 (permalink) Old 10-06-2004, 09:02 PM
[snapback]206391[/snapback]
i drive as hard as anyone here.. tats part of the fun of owning a BMW.. hard fast cornering!
<a href='
post #11 of 18 (permalink) Old 10-07-2004, 12:05 AM
Henri is an unknown quantity at this point
What will happen with speedometer when I'll change my 15'' stock tires with my new 17'' wheels? I know the tires will be more slim but will it be exactly the same size?
Thanks!
Henri
Henri is offline
post #12 of 18 (permalink) Old 10-07-2004, 12:14 AM Thread Starter
Here is a handy handy tire calculator that someone posted before....I'm thinking of gettting 19x8.5's with 235/35/19 tires...the tire calc says they would be 2.5% slower.
Tire Calculator
post #13 of 18 (permalink) Old 10-13-2004, 06:36 PM
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
When I had my 19x8 inch Konig Tantrums and my Ground Control coilovers all the way down I had no rubbing...When I went to 19x8.5/19x9.5 Axis Super Mesh wheels I had to raise the rear an inch to keep from rubbing..This pic was before I raised the rear.
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline
post #14 of 18 (permalink) Old 10-13-2004, 06:40 PM
Scarface's Avatar
Here are the old rims, note I had the rear down all the way with no rubbing...
Scarface is offline
post #15 of 18 (permalink) Old 10-13-2004, 07:03 PM
ArchangelX's Avatar
ArchangelX is an unknown quantity at this point
Send a message via AIM to ArchangelX
[snapback]206384[/snapback]
Fkn awesome! you just answered my question. THX!
ArchangelX is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
FS: 22 inch rims and tires NEW 7on22inchs Classifieds Sell & Buy 1 09-22-2004 10:56 PM
18" inch, Fittipaldi Diablo Rims - Tires mrbimmer Classifieds Sell & Buy 5 08-15-2004 01:43 AM
FOR SALE: 4 BBS Basketweave 14 inch Rims quiffy Classifieds Sell & Buy 0 06-28-2004 02:29 AM
wtb 17 inch rims NyteRyda Classifieds Sell & Buy 4 06-01-2004 02:34 AM
M3 CONTOUR 17 INCH RIMS ON 325IS?? nitrogass2000 3-Series (E36) 4 09-27-2003 09:29 AM
