Wierd 325i Problem??? - BMW Forum - BimmerWerkz.com
Old 10-26-2009, 11:23 AM   #1 (permalink)
VitaminC is on a distinguished road
Unhappy Wierd 325i Problem???
This is my first post in here so I appreciate all the help in advance. Here's the deal. I have a 1995 BMW 325i automatic. I can go outside and start it right up with no hesitation right now. The problem comes after I shut it off. When I go to restart it, it won't start. The first time I try to turn it over after I shut it off, it seems to try, but then it just turns over. It will just turn over from here on out. If I wait and let it sit for a while, it'll start right up and the whole thing just keeps going on. I have no clue what is causing this. Any information would be greatly appreciated. My name is Chris by the way.
VitaminC is offline   Reply With Quote
Old 10-26-2009, 04:48 PM   #2 (permalink)
nnamdi's Avatar
nnamdi is on a distinguished road
welcome to the forum VitaminC. Have you ever changed the fuel filter?
nnamdi is offline   Reply With Quote
Old 10-27-2009, 06:48 AM   #3 (permalink)
I was told that it was done just before I got the car from the previous owner, but I suppose it wouldn't hurt to change it. Also, an update, I read on some other forums and threads that someone was having a similar problem and checked out their fuel pump relay, so I pulled mine, gave it a few taps and put it back in. I was able to start the car over and over. I'm thinking I may just have a dirty/bad relay. I would still appreciate extra input though. Thanks.
1995 BMW 325i Automatic 168,000mi
Old 10-27-2009, 12:49 PM   #4 (permalink)
nnamdi's Avatar
Sounds like you've scored the winner here.
Old 10-27-2009, 12:57 PM   #5 (permalink)
I hope so, I'm going to air up the tires (back right one has slow leak) and drive it around for a while today and see how it does. Hopefuly I'll be back in business. Thanks for the input.
Old 10-27-2009, 01:48 PM   #6 (permalink)
nnamdi's Avatar
Cheers man
Old 11-05-2009, 11:10 AM   #7 (permalink)
toni_01 is on a distinguished road
Yea i am having the same problem with my 318i, at random times it starts and it doesnt, but it turns over fine it just doesnt start, where is the Fuel Pump relay located cause i might be having the same problem as yours.
toni_01 is offline   Reply With Quote
Old 11-07-2009, 08:56 AM   #8 (permalink)
On my 95 325i it is under the hood on the firewall on the drivers side. There is a box with a cap on it. You take the cap off and most of your fuses are under there. On mine, the fuel pump relay is the one in the front, right most bank or slot.
Wierd Turn Signal Problem theratdude64 3-Series (E21, E30) 13 10-24-2004 11:16 PM
Wierd Noise???? 98shaikh 5-Series (E12,E28, E34, E39, E60) 3 10-02-2004 11:01 AM
wierd Air Conditioner problem in '94 318 is ultraviolet353 3-Series (E36) 1 08-04-2004 10:40 PM
