whole lot of codes - BMW Forum - BimmerWerkz.com
Old 05-25-2008, 08:22 PM   #1 (permalink)
mab6680 is on a distinguished road
whole lot of codes
hi i have a friend who just bought a 96 328 i convertable my friend came by and asked me to hook my scan tool up because the cel was on the car runs and idles just fine but when i hooked up my scan tool these are the codes that came up
p1205
p0300
p0442
p0304
p0306
p0170
p1189
p1188
p0173
any clues on what to look for first
mab6680 is offline   Reply With Quote
Old 05-26-2008, 01:01 AM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
clear them and drive the car again when it comes back on read the codes again.
1992 318i Coupe parts car
I am Captain Obvious
Old 05-26-2008, 09:11 AM   #3 (permalink)
thank you for the fast reply i did clear the codes and random multiple miss fire came right back
Old 05-27-2008, 01:56 AM   #4 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
P1205 - bad injector cylinder 5
P0300 - multiple random misfire (plugs, wires, distributor/coil problem)
P0442 -EVAP small leak...
P0304 - misfire #4
P0306 - misfire #6
P0170 - fuel trim malfunction
P1189 - pump speed signal fault
P1188 - calibration memory fault
P0173 - fuel trim malfunction (b2)
If they all come back... change the brain. If only a few come back, let us know ;-)
Old 06-19-2008, 07:06 PM   #5 (permalink)
Ok so only three codes came back the three codes are
p1189 cylinder 4-6
p0173 cylinder 4-6
p0170 cylinder 1-3
Also my friend had another problem that started today. Every time he shut the car off fuse #31 blows. Then the car will not start intill he changes the fuse again. Any clues on what would cause this. Also the motor is an L6 2.8l DOHC. Thank You
Old 06-19-2008, 09:08 PM   #6 (permalink)
Cool
RE: CODES
P1189 denotes FUEL CONTROL Bank2 Sensor1
P0173 denotes Fuel Trim Bank 2
P0170 denotes Fuel Trim Bank 1
... given all three codes coming up at same time, i would factor these and start by inspecting your fuel filter. If u haven't changed it in awhile, I suggest you do.
While you doing that, inspect your filter... dirty? If yes, u got gunk in yo' tank that needs cleaning.
If clean... then suspect a weak or soon-to-fail fuel pump...
Old 06-20-2008, 03:54 PM   #7 (permalink)
OK i will give it a try over the weekend and get back to you once again thank you
Old 07-16-2008, 06:28 PM   #8 (permalink)
ok we changed the fuel filter and four codes came on but this time the cel did not come back on right after the car was started it took a couple of days this time here are the codes the poped up
p1188
p1189
p0173
p0170
Old 07-16-2008, 11:54 PM   #9 (permalink)
Arrow
uggh!... fuel trim problems... i hate these :-(
what it is fellas is that the brain cannot adjust the variables to achieve the 14.7:1 air to fuel ratio +/- a tolerable percentage. Several factors come into play here, unfortunately.
First, when was last tune-up? compression check, plug change(are they the correct range?), and air filter and don't forget the secondary air pump filter also. If these have not been serviced within any recent time, i suggest u do your basic tuneup first before you dig deeper. And don't forget to check for vacuum leaks.
Second, the sensors... AFM, TPS, 02 sensors. But let's not go into this for now.
Do the tuneup first so we eliminate the mechanical probs before u start probing the electrics.
* i almost want to suggest to go for a smog check- the readings for HC, CO, and NoX will surely provide a clue as to what could be wrong.
* when you take out the plugs, let me know the color of the electrodes.
Parking Lot Carnage offabroadway 3-Series (E21, E30) 4 08-29-2005 10:42 PM
Lot of miles smurray316 M-Series (M1, M3, M5, M6) 9 07-16-2004 01:03 PM
