Whistling Noise... - BMW Forum - BimmerWerkz.com
Old 07-07-2009, 05:14 AM   #1 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
Whistling Noise...
Ok, when i turn off the ignition i hear this loud whstling noise...
anyone know anything?
thanks.
carguy13 is offline   Reply With Quote
Old 07-07-2009, 12:33 PM   #2 (permalink)
325isBMW1988's Avatar
Car: 1998 328i
325isBMW1988 is on a distinguished road
Send a message via AIM to 325isBMW1988
strange....
325isBMW1988 is offline   Reply With Quote
Old 07-07-2009, 12:34 PM   #3 (permalink)
Car: 1998 328i
i just really wanted to use the Nelson emotion!
Old 07-07-2009, 01:19 PM   #4 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
thanks for all your help...
Old 07-29-2009, 03:17 PM   #5 (permalink)
Car: 316i e36 1997
merc450se is on a distinguished road
hi all,i also have a whstling noise from under the bonnet, i have a e36 316i
And also the funny thing is when it is cooler day it does not do it.
Anyone have any advice
merc450se is offline   Reply With Quote
Old 07-29-2009, 03:20 PM   #6 (permalink)
My first guess is there's a vacuum issue that needs to be found.
Old 07-29-2009, 03:23 PM   #7 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
My m3 just started this after my pulley esploded It seems like it is a vacuum leak causeing it(any Check engine light?)
1992 318i Coupe parts car
I am Captain Obvious
Old 07-29-2009, 03:31 PM   #8 (permalink)
Car: 316i e36 1997
hi, thanks for the quick reply, no engine lights are on and i have also replaced the rubber boot from the air box to the top of the engine.
any pointers anyone and if vacuum issue any idea where i should start?
Old 07-29-2009, 03:36 PM   #9 (permalink)
get a can on Carb Cleaner and spray a small amont on the connections of all the vaccum lines and hoses if the RPM rise you found your leak!
Old 07-29-2009, 04:10 PM   #10 (permalink)
Car: 316i e36 1997
hi, ok i will give that a go and let you know how i get on, will WD40 be ok to use?
Old 08-12-2009, 03:14 PM   #11 (permalink)
Car: 316i e36 1997
hi all, thats very much for all your advise.
I have now found the problem and the gasket on the inlet exhaust manifold is blowing.
Old 08-15-2009, 08:56 PM   #12 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Red face whistling?
thanks.
from what part of the car? under hood/bonnet... under your feet.... or backside?
Old 08-25-2009, 03:05 AM   #13 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
left side under the hood...it seems like it's only making the noise when the starter is working. hmmm....i don't know.
it doesn't make noise after the car is on, even when going speeds of 200kph...
i figured if it was an intake hose leak it would get increasingly louder as speed / rpm's increase.
Old 08-25-2009, 02:57 PM   #14 (permalink)
Cool
i can't help you if you cannot sdescribe properly:
1) your first post sez: "when u turn IGNITION OFF..."
2) now this post sez... "only when starter is working..."
that is 2 entirely opposite events.
and then speeds of 200kph???
Old 08-25-2009, 04:12 PM   #15 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
it's both, but one when i start the car it's real high pitched.
when i turn it off it's lower pitched.
whistling noise though speakers glyndawn Audio and Electronics 4 04-23-2006 11:38 PM
Whistling Noise... funtoos 3-Series (E36) 11 07-11-2005 08:35 AM
Loud Whistling Noise In Engine morristhecoolcat 3-Series (E36) 0 05-11-2005 02:54 PM
Bmw 2004 330ci Whistling/whinning Noise sanai79 3-Series (E46, E90) 4 11-05-2004 11:48 PM
Whistling noise mlseaver 3-Series (E46, E90) 3 04-12-2004 10:44 PM
