wheres the fuse box located at in my 92 325i - BMW Forum - BimmerWerkz.com
Old 03-21-2009, 01:43 PM   #1 (permalink)
325i_man's Avatar
Car: 1992 BMW 325i
325i_man is on a distinguished road
my dash lights went out on me and i need to locate the fuse box. all my lights and everything still works except for the cluster. maybe its just a blown fuse. any help would greatly be appreciated. thanks
1992 325i 4dr/5spd
325i_man is offline   Reply With Quote
Old 03-21-2009, 02:16 PM   #2 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
Under the hood between the brake booster and the fender. Instrument panel illumination should be position 22 5A also see 25, 33, 37.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 03-21-2009, 02:29 PM   #3 (permalink)
325i_man's Avatar
Car: 1992 BMW 325i
[QUOTE=jmo69;572678]Under the hood between the brake booster and the fender. Instrument panel illumination should be position 22 5A also see 25, 33, 37.[/QUOT
The previous owner too the sticker daigram off the cover so I don't know were the positions are at! This is my first bummer so I'm clueless on where the positions at. A link would be good too that for helping though too!!
1992 325i 4dr/5spd
Old 03-21-2009, 03:21 PM   #4 (permalink)
jmo69's Avatar
There's got to be a link to the Bentley manual pdf files someplace, I just can't find it. LOL
Found this, might be helpful http://www.bimmerwerkz.com/forum/3-s...box-44437.html
Old 03-21-2009, 03:28 PM   #5 (permalink)
HectorQ is on a distinguished road
Open the hood and on the right hand side there is a black box. Thats where the fuses are located. I also have the same model. I take a picture of it and posted in a few hrs when my sis get back with the car. I have the same model. One question i had related to this topic is how do you check if you have a blown fuse in there? I opened it up and it looks fine but some lights in the interior do not work for me, ex. the heater wheels and temp wheel lights. At least from the outside everything looks good but not sure the proper way to check a fuse. thanks
HectorQ is offline   Reply With Quote
Old 03-21-2009, 03:34 PM   #6 (permalink)
jmo69's Avatar
A continuity tester is the easiest, runs a low voltage to a light, no light no circuit.
Old 03-21-2009, 05:19 PM   #7 (permalink)
325i man ... i got the picture. Now i did noticed you asked for the 325i and i have a 92 325is. Either way send me a private message with your email or post it and ill email it to you because is too large to post here.
Old 03-21-2009, 07:10 PM   #8 (permalink)
325i_man's Avatar
Car: 1992 BMW 325i
[QUOTE=HectorQ;572701]325i man ... i got the picture. Now i did noticed you asked for the 325i and i have a 92 325is. Either way send me a private message with your email or post it and ill email it to you because is too large to post here.[/QUOTE
yang_jonathan97@yahoo.com
1992 325i 4dr/5spd
Old 06-23-2009, 10:56 AM   #9 (permalink)
Car: 93 BMW 325I
Chivas1 is on a distinguished road
When I turned my car on this morning same thing happened to me, instrument panel is not working. I've checked the fuses and they all seem to be good, can anyone tell me what else I should check??
thanks in advance
Chivas1 is offline   Reply With Quote
Old 06-24-2009, 03:16 AM   #10 (permalink)
David Mc's Avatar
David Mc is on a distinguished road
Check the dimmer switch on the back of the headlight switch. The dash lights draw power from there and if it has been turned all the way down, they will be out. Faults are also commoin in the switch.
David Mc is offline   Reply With Quote
Old 06-24-2009, 10:47 AM   #11 (permalink)
Car: 93 BMW 325I
everything works on the cluster except for the needles & the odometer reading.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
fuse box alexus16 3-Series (E46, E90) 1 10-05-2008 06:40 AM
fuse box cymorg 3-Series (E36) 5 02-22-2006 07:52 AM
wheres my PCV located ? j123crx 3-Series (E21, E30) 1 11-07-2005 08:33 PM
Fuse Box shield 3-Series (E21, E30) 5 09-15-2004 04:11 AM
HELP, Wheres my ECU located.....???? ME-TAZ 3-Series (E36) 2 01-13-2004 03:59 PM
