Wheels and tires - BMW Forum - BimmerWerkz.com
Old 10-25-2005, 01:38 PM   #1 (permalink)
kobidog is on a distinguished road
Wheels and tires
I have a 96' 328 and want to get some rims put on it.
I was looking at some 19" 8.5 front and 9.5 rear with 235/35 fronts and 245/35 rears.... I believe I have to roll the back fenders... how about the front? Will there be any other problems?
Thanks in advance..
kobidog is offline   Reply With Quote
Old 10-25-2005, 02:36 PM   #2 (permalink)
SpooldUp's Avatar
Car: 99 323i ragtop
SpooldUp will become famous soon enoughSpooldUp will become famous soon enough
Send a message via AIM to SpooldUp
Yes, you will need more wheel offset and rolled fenders. Tirerack rents the fender roller tool you need to do it yourself. If you call them or email them, they will give you the exact information on the tool and dimensions you will need.
Did I mention tirerack rules?
'99 323i 5spd
<CENTER>
</CENTER>
where's my beer?
best website ever
"I'm not even supposed to be here today"
SpooldUp is offline   Reply With Quote
Old 10-25-2005, 03:01 PM   #3 (permalink)
what do mean I will need more wheel offset? Bigger tires in the back?
I saw an ad for 265/30/19.... is that possible?
thx,
Old 10-25-2005, 03:55 PM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
not only will the rims be too wide for the fender
, but they will rub the inside of the wheel well...
-SOLD..
R.I.P Fast 6
Old 10-26-2005, 08:50 AM   #5 (permalink)
so I can't go with 19's or I can't do 19 X 9.5 in the rear?
Thx,
Old 10-26-2005, 02:46 PM   #6 (permalink)
SpooldUp's Avatar
Car: 99 323i ragtop
read this page about offsets
Stock offset is 47mm
This means the centerline of the wheel (as viewed from above with the tire rolling) is 47mm away from where it is bolted to the hub. So, think of it as negative offset.
I believe 35mm is the lowest you can go
This would relocate the centerline of the wheel 12mm outward. this is ok if you are using tires that will be no wider than 24mm+stock. Get it?
If you are looking at 245mm wide tires, they will rub with an offset of 35.
205(stock)+24 ~ 230 (you could go a little higher that this as there is some extra room even with the stock tire setup). Maybe 235?? Also, the fenders need to be rolled.
Keep in mind that more offset will allow they to fit, but put more stress of all of your suspension. Also keep in mind that fat tires will cause the car to pull to the side when driving on an uneven road.
Confused?
Summary:
9.5 in rims are 241 mm wide themselves. So this is not possible without using low affsets and spacers/longer wheel studs.
8.5 in rims = about 215 mm wide, so fitting them with 235 wide tires (with a 35 offset wheel) should not be a problem even on the front with extra weight and hard cornering.
Maybe think about 8 in the front, and 8.5 in the rear. Again not to say that 9.5 WILL NOT work, it will just take more work and money on your part to do it right!
Cheers
'99 323i 5spd
<CENTER>
</CENTER>
where's my beer?
best website ever
Old 10-27-2005, 10:33 AM   #7 (permalink)
great... thats perfect...
Thanks for taking the time to responding... I live in the Cayman Islands and have to order the rims in, I can't just drive in and get them assessed....
I'll FedEx ur beer.... Cheers...
545 Sport Wheels And Nitto Tires 4 Sale 98bimmerhead Wheels and Tires 1 06-07-2007 04:18 PM
Oem 17 Inch 2003 545i Wheels With Tires stuk0ny0u Wheels and Tires 1 07-11-2005 07:06 AM
Fs: 19" Bmw Wheels With Michellin Tires BAD Classifieds Sell & Buy 0 11-22-2004 11:30 AM
Wheels and Tires Package BMWChicago 3-Series (E36) 0 01-26-2004 05:59 PM
