Originally posted by CyPHER@Nov 27 2003, 11:19 AM Yeah, I have some 18" MASItaly rims and they constantly hit the wells. I think I may get stiffer suspension and see how that works. |
Make sure you get the right offset bigger is not always better all OEM rims are about 20-35lbs and the 18s you got is probably over 45lbs each that’s extra 10-15lbs the axel has to carry and the wide tires puts a lot of stress on the Power steering pump.
I had some big ones on before when I turned and hit a bump at the same time the inner fender cut a piece of my tire off and bend the fender out some too. So inclosing don’t put what you think looks good on the car put what’s right on your BABY!!!
