Wheel Removal - BMW Forum - BimmerWerkz.com
Old 10-13-2004, 08:19 AM   #1 (permalink)
93 325i's Avatar
Recently had a nail in a tire..I tried to use the stock lug wrench to get the bolts out and it wouldnt budge at all. So i decide to stomp on the lug wrench thinking that would work and the friggin head of the lug wrench snaps off! So I Buy a new *stronger* wrench and get the bolts out...but.....wheel is now fused to the rotor...eventually I get the wheel off after using PB Blaster & much convincing. Obviously the wheels were on there a while but has anyone else run into this? And this is warning to those who havent taken a wheel off in a while- it will be a PITA..
Complete mod list and pics:
My 1993 325i
Old 10-13-2004, 08:24 AM   #2 (permalink)
Storamin's Avatar
Storamin is an unknown quantity at this point
My friend got a flat in his e30 over the summer and we were trying to change it. Eventually we had to call his dad to bring a mallet. We hammered at thing for at least 20 minutes to get it off. Not to mention, they had been taken off about 4 months before.
Storamin is offline   Reply With Quote
Old 10-13-2004, 09:10 AM   #3 (permalink)
I had problems getting mine off to when I was changing rotors. I think bavauto has some something that goes inbetween the wheel and rotors to keep from rusting on.
Old 10-13-2004, 09:35 AM   #4 (permalink)
BLACKBMW's Avatar
BLACKBMW is an unknown quantity at this point
Use a wire brush on the boss and remove any crap - then when you put the wheel back on you can smear some grease on the inside of the rim - this will help the next time you want to take them off
hope this helps
J...
<img src='http://img.photobucket.com/albums/v629/BLACKBMW1/alssig.jpg' border='0' alt='user posted image' />
Thought for the day: &quot;d'uh&quot;
BLACKBMW is offline   Reply With Quote
Old 10-13-2004, 09:37 AM   #5 (permalink)
Kraftfahrer is an unknown quantity at this point
[snapback]210437[/snapback]
Yeah, I ran into this this summer. The easiest way to get it off when it is stuck like that is to loosen the lug nuts a little, drive the car slowly around for a few seconds, jack it back up, hammer with a mallet, and try getting it off again. It worked for me after one run around a parking lot.
BAN SCHILKE!
Kraftfahrer is offline   Reply With Quote
Old 10-14-2004, 11:38 AM   #6 (permalink)
nycbmw325is is an unknown quantity at this point
hope this helps
J...
[snapback]210463[/snapback]
If you guys read the BMW service I or II (i forget which) detail it mentions removing wheels cleaning center hub and putting anti sieze compund on. DO NOT use grease as BLACKBMW suggests as unless it is specifically designed to withstand the high heat that the rotor generates it can melt get on your rotor and cause your brakes to not function.
I use high temp anti sieze compund which can be purchased in most auto store. By the way you should be using this stuff on all of your lug bolts as well.. takes almost no extra time and makes life so much easier down the road.
nycbmw325is is offline   Reply With Quote
Old 10-14-2004, 11:57 AM   #7 (permalink)
ex owner/admin
Furious's Avatar
happens all the time, usually when the car is on the lift,, i throw one bolt on loose and then give the tire a good roundhouse.
Old 10-16-2004, 08:17 PM   #8 (permalink)
BLACKBMW's Avatar
Originally posted by nycbmw325is+Oct 14 2004, 10:38 AM--><div class='quotetop'>QUOTE(nycbmw325is @ Oct 14 2004, 10:38 AM)</div><div class='quotemain'><!--QuoteBegin-BLACKBMW@Oct 13 2004, 08:35 AM
hope this helps
J...
[snapback]211126[/snapback]
[/b][/quote]
I've used a smear of grease for over 15 years on numerous cars on the wheel boss with no ill effects - maybe the brand I use is high heat
Does The Weight Of A Wheel Really Matter andrewgrhogg 3-Series (E36) 19 08-17-2005 01:31 AM
Airbag & Steering Wheel Removal Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 2 08-15-2005 01:28 PM
Ahh..... The Age Old Question liltrig99 3-Series (E36) 11 08-04-2005 02:29 AM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
