whats ur ride idle at? - BMW Forum - BimmerWerkz.com
Old 09-02-2004, 09:52 PM   #1 (permalink)
/Banned
okczy21 is an unknown quantity at this point
whats everyones car idle at?
okczy21 is offline   Reply With Quote
Old 09-02-2004, 10:01 PM   #2 (permalink)
Spook's Avatar
Spook is an unknown quantity at this point
Right now (I assume I need to get her tuned up in the next few days to improve this a touch and stop the slight chugging at idle) it sits at about 700-750. This is a good question, or leads to one...What should the idle be on a '92 318I? I thought most would be about the same, but thought I'd ask.
Spook is offline   Reply With Quote
Old 09-02-2004, 11:07 PM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
750 is about normal.... any higher, and i would get it checked out!
-SOLD..
R.I.P Fast 6
Old 09-02-2004, 11:07 PM   #4 (permalink)
chungaa1 is an unknown quantity at this point
well,
i have a 1993 325i.... my baby idles cold~600
hot~700~750
steady flow baby.... no leaks here......
tits and ass....
laters,
eric
chungaa1 is offline   Reply With Quote
Old 09-02-2004, 11:15 PM   #5 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
mine idles from 750-3000 rpm, sometimes just randomly it will go up to 3000 rpm..
xsperf is offline   Reply With Quote
Old 09-02-2004, 11:31 PM   #6 (permalink)
3000?? omg!! you better open up your hood and find the problem.....
Old 09-02-2004, 11:39 PM   #7 (permalink)
ex owner/admin
Furious's Avatar
on cold days (talking winter time) it starts out at around 1000k but once its warm or its warm out, its usually 600-650
Old 09-03-2004, 12:14 AM   #8 (permalink)
/Banned
just wanted to know cause at idle my tach sits at 0, so at the most its off 750 rpm
Old 09-03-2004, 01:15 AM   #9 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
You put your needle on at the wrong place, take apart your gauges again and make sure to put it back on correctly. I think that this should fix your problem.
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 09-03-2004, 09:08 AM   #10 (permalink)
/Banned
well it seems like when the car warms up it idles at about 600, but right when i start the car and driving around town until i hit highway it sits at 0 and fluctuates when im on the gas
Old 09-04-2004, 04:48 AM   #11 (permalink)
2.link's Avatar
Old 09-04-2004, 04:55 AM   #12 (permalink)
_1634_ is an unknown quantity at this point
I have a question for you all:
1994 325is / 5 speed / 92,000 Miles
When starting cold, my car hits close to 2,000 rpm when i turn the key (clutch depressed, shifted into first gear) and i can feel a difference from when i start warm. then engine drops to ~750rpm
when i start warm: tachometer hits right below 1,500rpm and drops to ~750rpm
i think i feel a slight pressure on either my clutch pedal or my shift knob when starting cold that i dont feel when starting warm (or at least the pressure isnt at a level where it is noticeable)
is this all normal?
thank you
<span style='font-family:Arial'>1994 BMW 325is // White // 5 Speed
Slotted Rotors // Hawk HPS Pads <span style='color:blue'>//</span><span style='color:red'>/</span>Motorsport Shifter // De-Baffled Airbox</span>
_1634_ is offline   Reply With Quote
Old 09-04-2004, 07:52 AM   #13 (permalink)
/Banned
xsperf's Avatar
heh, what the hell do i know, mine idles at 3 thousand rpm!
Idle Problems BeelZibub 5-Series (E12,E28, E34, E39, E60) 10 07-10-2005 04:56 AM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
Warmed up idle puzzle. nightsurfride 3-Series (E21, E30) 2 02-03-2004 08:04 PM
