whats this light mean???? - BMW Forum - BimmerWerkz.com
Old 01-06-2007, 11:42 PM   #1 (permalink)
hunter325i's Avatar
Car: 1993 325is
hunter325i is on a distinguished road
im new to bmw's, got a 1993 325i yesterday and im trying to learn as much as i can.
hunter325i is offline   Reply With Quote
Old 01-07-2007, 12:08 AM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Your front and/or rear brakes have worn down to the sensor. You now have 2mm of pad left until the brakes go metal to metal. You will most likely need new rotors to go with the pads and a new wear sensor.
My M50 Powered E30 Page
Old 01-07-2007, 12:09 AM   #3 (permalink)
hunter325i's Avatar
Car: 1993 325is
ok but theres new brakes rims and tires all around?????
Old 01-07-2007, 12:59 AM   #4 (permalink)
WOT in Reverse
jllphan's Avatar
ok but where the sensors replaced when the new pads were put on? If not, your warning light would still be lit. 2 sensors --one front one back, driver's side i believe. You should be able to get for 10bux or so at your local autohaus
Old 01-07-2007, 01:10 AM   #5 (permalink)
hunter325i's Avatar
Car: 1993 325is
ok thanks, this is my first bmw, so im learning along the way...
Old 01-07-2007, 01:16 AM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
If the light was out after they put new brakes and wheels on the car and now the light has just come on they may have routed the sensor wire incorrectly and it has worn through on the wheel causing the light in the dash to come on. But if the light was on before they did the brakes is still on you more than likely need a new sensor.
Old 01-07-2007, 01:17 AM   #7 (permalink)
hunter325i's Avatar
Car: 1993 325is
no the light was on before...im guessing no new sensors were put on....ill check it out. thanks
Old 01-10-2007, 12:47 AM   #8 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
If you need extra help take a photo for us of the brake pads. We can determine whether the pads are new or if it's just poor workmanship and lack of replacing a sensor.
Old 01-10-2007, 01:30 AM   #9 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
not always true, my lights been on for almost a year, sensor went bad....
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
break light enclosure question vic318ic 3-Series (E36) 12 04-27-2006 10:21 PM
DDE/City Light Switch 97alpineM3 3-Series (E36) 14 02-04-2006 11:07 PM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 10:30 PM
