What size injectors are on the 318 and 325/328? - BMW Forum - BimmerWerkz.com
Old 03-31-2004, 05:24 PM   #1 (permalink)
nick_g_evans is an unknown quantity at this point
So, are the 6 cylinder injectors bigger than the 4 cylinder? I wouldn't think so, but I hope so. Anybody know the stock sizes?
nick_g_evans is offline   Reply With Quote
Old 03-31-2004, 11:57 PM   #2 (permalink)
Defector
El Presidente's Avatar
my book shows them to be the same, but does not mention flow rate, but the FPR is set to 43.5 on both, so I imagine flow is the same.
Old 03-31-2004, 11:59 PM   #3 (permalink)
What book? The Bentely? I couldn't find it in there.
Old 04-01-2004, 12:04 AM   #4 (permalink)
Defector
Actually the cheap Haynes manual.
Old 04-01-2004, 03:41 AM   #5 (permalink)
Super Moderator
dutchbmw's Avatar
They're not the same. The 325i/328i works also with higher fuel pressure!
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 04-01-2004, 12:42 PM   #6 (permalink)
Andrewsd1985's Avatar
Andrewsd1985 is an unknown quantity at this point
Send a message via AIM to Andrewsd1985
What would be good injectors to upgrade to in a 325?
PRESIDENT OF THE OVER 10 YEARS OLD AND UNDER 100K MILES CLUB
1993 325i 5spd
Benfer Performance Intake
M-tech Pedals and Shiftknob
Bavarian Auto Floor Mats
Wheelskin Steering Wheel Cover
Panasonic Head Unit
Euro Projector Lights w/ black Housing
Black Housing Clear Corners
Dinan Chip
MORE TO COME!!
<img src='http://plaza.ufl.edu/dunna/Pictures/banner.jpg' border='0' alt='user posted image' />
Andrewsd1985 is offline   Reply With Quote
Old 04-01-2004, 10:57 PM   #7 (permalink)
Defector
the only reason you would need larger injectors is if you biult a full race motor or went FI with a high PSI. Otherwise, you'll be wasting the money.
Old 04-01-2004, 11:28 PM   #8 (permalink)
Kevin325i's Avatar
werd
Adding bigger injectors might give you a tiny gain. Going too big will cause your car to die when you stop on the gas. Maybe if you had a big intake so you needed more fuel to mix in otherwise you'd just run rich the whole time.
I'd say just have the injectors cleaned and put the money you'd spend on new injectors into a chip.
Just my $0.02
Kevin (President TBEA)
Old 04-01-2004, 11:54 PM   #9 (permalink)
Defector
if this was an POS car then you would probably see a gain, but because the DME determines how much fuel is neeeded, larger injectors won't automatically flow more fuel; they have to be told to. If they did flow more you just be running rich.
Old 04-02-2004, 04:15 AM   #10 (permalink)
Super Moderator
dutchbmw's Avatar
But why the're different injectors for 318 / 325?
BTW, it's right the DME controls the flow!
BMW '96 M3 (SOLD)
Old 04-02-2004, 11:28 AM   #11 (permalink)
Defector
According to my book they arent any different. They operate at the same pressure.
The logic that the i6 needs bigger injectors to produce more power is flawed. The i6 produces more power because it has 2 more cylinders, but does not need more fuel flow to do so.
Old 04-02-2004, 11:43 AM   #12 (permalink)
Positive5 is an unknown quantity at this point
Now when you say "controls the flow" you are talking about pulse width? I would assume because the pressure is controled by the regulator so because the DME reads the signal from the MAF, all conversions for baro.,temp. and speed are all accounted for. SO adding bigger injector wont have a power gain unless it is running lean for some other reason.
Positive5 is offline   Reply With Quote
Old 04-02-2004, 11:57 AM   #13 (permalink)
Super Moderator
dutchbmw's Avatar
Here a copy of my book:
What size injectors are on the 318 and 325/328?-injectors.jpg
BMW '96 M3 (SOLD)
Old 04-03-2004, 12:10 AM   #14 (permalink)
Defector
interesting. I do not have my camera at home, but I shall take a pic of my manual on monday that says they are the same.
Old 04-03-2004, 09:49 AM   #15 (permalink)
Super Moderator
dutchbmw's Avatar
Even I don't if M50 is different from the VANOS engines, the info in my book is from the M50 engine!! I thought the M52 is VANOS??
BMW '96 M3 (SOLD)
