| I want to get a center console cupholder for my '94 325i. Bavauto only sells the one-piece set (2 cupholders, coinholder, place for ashtray). The setup I want is the modular version where you can move the cupholders around. Pelican Parts sells that version (actually, sells the separate modular parts).
However, PelicanParts states that it's only "For cars with the later style center console frame, you can alternate the accessory inserts in your console simply by pulling them out and switching them around. You can also convert to the later style frame to accept these inserts. Check the photos below to identify the correct type of console that these inserts work with."
SO MY QUESTION:
__________________ <span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal! |
