What Is My Cars Problem!!!????? - BMW Forum - BimmerWerkz.com
Old 01-05-2005, 10:30 AM   #1 (permalink)
spfdfanatic's Avatar
spfdfanatic is an unknown quantity at this point
The tires on them are used, but with my old wheels, ride was perfect went from 15's to 17's. With the new wheels, every bump in the road makes the car pull left or right, feels very unstable. The wheels are true, and balanced, and the offset is perfect, is there maybe something like a new alignment i should get done, or could it be that the tires were used, and maybe not set up right for the car??? Anyone ever have issues after going to the bigger wheels??
spfdfanatic is offline   Reply With Quote
Old 01-05-2005, 10:40 AM   #2 (permalink)
bimmer_boy's Avatar
bimmer_boy is an unknown quantity at this point
Send a message via AIM to bimmer_boy
[snapback]264779[/snapback]
You will always get a rougher ride the bigger the wheel you go with. Not only is the larger wheel making the ride rougher, but you probably have low profile tires on the larger rims which provide less rubber between the rim and the road thus making you feel things a bit harsher. The stability prbablem is probably the result of the low profile tires. They tend to "tramline." (I think that's the correct term) Meaning they follow the road. They'll pull whichever way the road dictates. Do a search and I'm sure you'll come up with a bit more information.
BLACK 1995 BMW E36 325i
• <u>Dinan</u> Performance Software - SOLD!
• High-flow intake w/ Green Performance Filter
• 17 x 8.5 BMW Style 44 Rims
• <u>Pirelli</u> P6 tires 235/45/17
• M3 Spoiler
• Clear Tail Lights, Corners, and Side markers
• 20% Tint all around
• Sylvania Silverstar Bulbs
• <u>Alpine</u> 9831 MP3/CD Player
bimmer_boy is offline   Reply With Quote
Old 01-05-2005, 10:49 AM   #3 (permalink)
So I guess there is not much i can do about it??? New tires would not help??
Old 01-05-2005, 11:05 AM   #4 (permalink)
YoungExec728 is an unknown quantity at this point
Not really much you can do, it's normal with bigger, wider, low profile tires. Make sure your air pressure is correct too.
<img src='http://memimage.cardomain.net/member_images/9/web/741000-741999/741934_9_full.jpg' border='0' alt='user posted image' />
JC Chip * Cosmos Racing CAI * UUC System U * UUC Underdrive Pulleys * Fan Delete * UUC Sachs Stage 4 Suspension * Sway Barbarians * Racing Dynamics Front strut bar * X-Brace * Front Camber Plates * UUC TME * BBS 18x8.5 * 235/40/18 Yokohama AVS Sport * F&amp;R Zimmerman X-Drilled Rotors * SS Brake Lines * Rouge RSM w/enforcers * Clears all around * SilverStars * Pioneer Avic N-1 * Pioneer 6 Disc Changer * JL 450/4 and 1000/1 Amplifiers * 2 JL 12&quot; W6V2 * Diamond Audio Hexs 6.5&quot; in kick panel * MB Quart Premiums 4&quot; in Rear * Infinity Kappa 3.5&quot; in door * Batcap 400 * Optima Yellow Top
YoungExec728 is offline   Reply With Quote
Old 01-05-2005, 11:23 AM   #5 (permalink)
93 325i's Avatar
The tires on them are used, but with my old wheels, ride was perfect went from 15's to 17's. With the new wheels, every bump in the road makes the car pull left or right, feels very unstable...
It shouldnt be that bad..I had 17's on all my cars. The ride is def. more harsh but the car shouldn't feel unstable. Maybe your just not used to it yet.. There could be some worn suspension componets that you feel now cuz of the bigger rims and/or the wear pattern on the tires could also be contributing to it. I would just continue driving on them and see if it improves.
Complete mod list and pics:
My 1993 325i
Old 01-05-2005, 11:58 AM   #6 (permalink)
JV2000 is an unknown quantity at this point
Yeah when I got my 18's I had that problem, and the steering wheel started shaking at high speeds. I just got the wheels high speed balanced and they were good to go. I thought I needed an alignment but the guy at the BMW place could not do it because my rims were not stock. You probably just need to get used to the new ride.
JV2000 is offline   Reply With Quote
Old 01-05-2005, 08:28 PM   #7 (permalink)
spieluhr's Avatar
spieluhr is an unknown quantity at this point
Send a message via AIM to spieluhr
like everyone said your stuck with it. when i went to 18"s my car did the same thing, and still does. but to look at it positively though you will now perform better in the turns now with bigger stiffer wheels and im guessing wider tires so just drive faster and windier roads and you will be happy!!!
<img src='http://img268.echo.cx/img268/1430/zkwsig23iq.jpg' border='0' alt='user posted image' />
1996 328is Black
Suspension: MB Motoring 18x8, Kuhmo Supra 225/35/18ZR
Audio:Eclipse CD3414 HU
Lighting: ZKW W/ DDE PLUS
spieluhr is offline   Reply With Quote
Old 01-05-2005, 09:39 PM   #8 (permalink)
[snapback]265169[/snapback]
Hmm, kinda upsets me because I had such a smooth ride on my 15's, wondering if a little more profile in the tire might help!!!
Junk Yards List USA SpeedInfusion Bimmer Talk/Motorsports Talk 19 09-12-2008 08:09 AM
Whats With Manual Cars? Automatic Cars Better? Delmarco 3-Series (E36) 81 03-11-2005 04:25 PM
Honada's new AWD system bimmer_boy Other Rides 20 08-02-2004 01:51 AM
