What Headlamps Will Fit An E36 Compact? - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 06-02-2005, 08:16 AM Thread Starter
swindon_matt_uk is an unknown quantity at this point
Send a message via MSN to swindon_matt_uk
Hello everyone, need to get some new headlamps. Whats the difference with the 4 door headlamps and ther Compacts?
Aren't they the same? The reason is because I can only find some Angel eyes for the 4 door. I have 4 door clear indicators, so I'm thinking the headlamps are the same?
Many many thanks in advance,
Matt
<span style='font-size:14pt;line-height:100%'>-=CheeRS=-</span>
<img src='
swindon_matt_uk is offline
post #2 of 7 (permalink) Old 06-02-2005, 12:50 PM
mech9T8's Avatar
mech9T8 is an unknown quantity at this point
I believe all E36's use the same headlights.
<img src='
<span style='color:blue'>My ass may be dumb, but I ain't no dumb ass!</span>
mech9T8 is offline
post #3 of 7 (permalink) Old 06-03-2005, 08:21 AM
Boxbrownie's Avatar
Boxbrownie is an unknown quantity at this point
Send a message via AIM to Boxbrownie Send a message via MSN to Boxbrownie
NO NO NO.........carefull Matt, the compact has US style headlamps in that it uses reflector lamps and 900X series bulbs (not very good really) the rest of the range use ellipsoid headlamps for dip and reflector for main, a much better set up.
Do as I did and convert to the ellipsoid versions, physically they will straight swap, but you need to change the wiring socket on the loom at the headlamp each side, just go to a breakers and pick up the small section of loom that plugs in to the ellipsoid type headlamp (large bayonet fixing plug) and replace existing compact sockets (2 each side and sidelight) with the new versions, then just bolt in the ellipsoid headlamps and see the difference!
It a real worth while mod.
Best regards David
Boxbrownie is offline
post #4 of 7 (permalink) Old 06-03-2005, 08:28 PM Thread Starter
Hi mate, thats great cheers. I was wondering, could you drop me your number to: swindon_matt@hotmail.com and then I could call you just to ask a couple of things. I would be very grateful if you didn't mind.
Matt
<img src='
post #5 of 7 (permalink) Old 06-06-2005, 09:42 AM
mech9T8's Avatar
My mistake, there are US spec and Euro spec headlights. But they should be a universal fit across all E36's.
<img src='
mech9T8 is offline
post #6 of 7 (permalink) Old 06-08-2005, 03:19 AM Thread Starter
I have since found out they are very different. They fit, but wiring is diffeferent. Regardless of whether they are US or EURO.
<img src='
post #7 of 7 (permalink) Old 06-08-2005, 03:31 AM Thread Starter
See, theres one of my headlamps. The standard ones use ellipisoid lamp alongside the conventional lamp.
But the Compact uses just 2 normal lamps as you can see.
You learn something new everyday.
Also - the Compact lamps uses about 3 plugs but the saloon version uses a fat multiplug. :nana
<img src='
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 02:39 PM
NEW E36 Rear Axel Bearings jroozee OEM Parts 0 11-06-2005 10:33 PM
my comparison e30 vs e36..I own both Trob 3-Series (E21, E30) 4 10-04-2005 05:27 PM
