What Does Your Thermostat Usually Read? - BMW Forum - BimmerWerkz.com
Old 04-10-2005, 08:34 PM   #1 (permalink)
BMW-ATI's Avatar
BMW-ATI is an unknown quantity at this point
Send a message via AIM to BMW-ATI
what does your theromostat usually read after driving for awhile, mines at the halfway mark,
and btw, how do you bleed you radaitor? is it suggested, cause ive never done it, should i?
is it hard
thx
BMW-ATI is offline   Reply With Quote
Old 04-10-2005, 09:08 PM   #2 (permalink)
dark_islight's Avatar
dark_islight is an unknown quantity at this point
is it hard
thx
[snapback]329705[/snapback]
Temp guage needle should be dead center.
To bleed the rad: Remove the small plastic bleed screw to the right of the radiator cap. On M3 engines, this screw is located on the thermostat housing. Using a large funnel in the expansion tank, slowly fill the car with new coolant. Use a 50/50 mixture of antifreeze and distilled water. Do not use tap water or spring water, as these have impurities that will contaminate your system. Distilled or ionized water is 100% H20, and does not contain any minerals, additives, or impurities. Fill the system very slowly, as it will take a bit of time for the coolant to get to all points in the system. On 4-cylinder cars, you will need about 7 quarts (6.5 liters). For the six cylinder cars, you will need 10.6 quarts (10 liters). M3 motors require 11.1 quarts (10.5 liters).
Click on Figure 13
When the system is full of coolant, you will need to bleed air out of it. This applied only to the cars that have the expansion tank attached to the side of the radiator. Other BMWs with a separate, external expansion tank are self-bleeding. The procedure for bleeding these cars seems somewhat sloppy and not too slick. With the bleed screw removed, fill the expansion tank until fluid begins coming out of the bleed screw. Continue filling until there are no more bubbles coming out, as shown in Figure 13. This, of course will mean that plenty of coolant will spill all over your radiator, and down onto the ground. Have a catch pan ready to capture this coolant spill. When no more bubbles exit out of the bleed screw, tighten it to 8 Nm (71 in-lb).
Now, run the engine until it reaches it's operating temperature. Turn off the engine and let it cool down. Then, top off the coolant in the expansion tank to the appropriate level, if necessary.
Check this website for more DIY
Do it yourself
dark_islight is offline   Reply With Quote
Old 04-10-2005, 09:08 PM   #3 (permalink)
JL380 is an unknown quantity at this point
is it hard
thx
Mine is at the halfway and i think all are at the halfway mark most cars are before the halfway mark. This is normal
JL380 is offline   Reply With Quote
Old 04-11-2005, 12:13 PM   #4 (permalink)
PR325is is an unknown quantity at this point
Send a message via AIM to PR325is Send a message via Yahoo to PR325is
Originally posted by JL380+Apr 10 2005, 10:08 PM--><div class='quotetop'>QUOTE(JL380 @ Apr 10 2005, 10:08 PM)</div><div class='quotemain'><!--QuoteBegin-BMW-ATI@Apr 10 2005, 07:34 PM
is it hard
thx
[snapback]329739[/snapback]
[/b][/quote]
THAT'S NOT TRUE... EVEN THOUGH MY THERMSTAT GAUGE READS DEAD CENTER, NOT ALL CARS REGULAR TEMP. STAY AT THE MIDDLE... SOME CARS READINGS STAY AT 1/4...
PR325is is offline   Reply With Quote
Old 04-11-2005, 12:50 PM   #5 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
Originally posted by PR325is+Apr 11 2005, 11:13 AM--><div class='quotetop'>QUOTE(PR325is @ Apr 11 2005, 11:13 AM)</div><div class='quotemain'>
is it hard
thx
[snapback]330098[/snapback]
[/b][/quote]
RIGHT ANSWER. A+++ Mine reads dead center also, just to help comfirm yours is normal for an e36, but like he said, some makes like ford and chevy for example usually are below the halfway mark.
kyle_baker is offline   Reply With Quote
Old 04-12-2005, 11:15 PM   #6 (permalink)
BMW-ATI's Avatar
mine's like literally a MM past the halfway, is that ok?
it kinda goes back in forth between being a little bit before dead center, to a TINY TINY TINY bit past
Transmission cooler Thermostat? Laker 3-Series (E36) 5 02-27-2009 01:36 PM
Thermostat Replacement Question bmw325ci 3-Series (E46, E90) 1 01-27-2005 02:33 PM
Thermostat Installed Upside Down, Maybe? YoungExec728 3-Series (E36) 2 12-09-2004 03:15 PM
Thermostat Gasket/o-ring? Brian325i 3-Series (E36) 5 10-02-2004 02:30 PM
