What do i need from the donor? - BMW Forum - BimmerWerkz.com
Old 08-28-2009, 11:44 PM   #1 (permalink)
Car: 1992 318i
E36GRIP is on a distinguished road
So i picked up a donor car tonight (325is). only problem is i probably cant have the extra car laying around for more than a week or so, so i need to yank the goods asap.
**question**
what all do i need to pull out to do the engine swap?
FYI the rest will be parted out so stay posted so i can let you guys know whats up for grabs.
E36GRIP is offline   Reply With Quote
Old 08-29-2009, 04:10 AM   #2 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
can you rent a spot at a garage?
being overseas, that's what i would have to do.
you don't want to rush something that big...unless your a pro and do it all the time...then no worries.
it's a 325 to 325 right?
carguy13 is offline   Reply With Quote
Old 08-29-2009, 08:15 AM   #3 (permalink)
CanadianWraith's Avatar
Car: 1996 318is
CanadianWraith is on a distinguished road
looks like a 325 into 318 swap
CanadianWraith is offline   Reply With Quote
Old 08-29-2009, 08:33 AM   #4 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
hmmm....is the transmission going to line up?
i believe the 318 has a 4 cyl right? and i know that the 325 has a 6, but i'm not sure if the equipment will fit.
the exhaust will probably have to be custom made, but other than that i'm not experienced enough to say...
either way, i would love to see tons of pics to keep up with your progress!
Old 08-29-2009, 03:19 PM   #5 (permalink)
Car: 1992 318i
yeah its 325 to 318, i dont need to install it all right away, i just need to get all the stuff ripped out so i can send the rest to the junk yard
heads up guys i im about to post an entire interior in the classifieds
Old 08-29-2009, 05:07 PM   #6 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Off the top of my head, I guess you'll need:
- engine
- transmission
- exhaust manifold/catalytic converter/exhaust
- engine electronics and all associated wiring harnesses.
- intake/airbox
- entire cooling system
- differential
You'll definitely need the stuff above. I don't know what else I am missing. You may want to just gut out the entire engine bay and hold on to everything in there.
Turkey Fleet Bond Holder
Old 08-29-2009, 05:09 PM   #7 (permalink)
Car: 1992 318i
may be a dumb question, but.... any chance the motor will bolt up to the one i have in my 318? the trans is f'ed in the donor
Old 08-29-2009, 05:40 PM   #8 (permalink)
drz
drz's Avatar
Car: zhp
Should work just fine. I just checked and the 318 and 325 were fitted with the same transmissions.
Is your car auto or manual?
Old 08-29-2009, 05:47 PM   #9 (permalink)
Car: 1992 318i
its a manual, and you are now officially my fav. member for telling me that!!!!!
Old 08-29-2009, 06:19 PM   #10 (permalink)
drz
drz's Avatar
Car: zhp
I double-checked and just want to add something. See, the 318i was fitted with the Getrag S5D 200 G transmission up to 9/1992, but then they started using the Getrag S5D 250 G. The 325i always used the Getrag S5D 250 G.
If you have the 250, you're good to go. I don't know what the spec differences are between the 200 vs the 250, but I think they should bolt right on to the engine. I'd try to make sure that if you have the 200 (most likely, since I see your car is a 1992 model year), that it can handle the torque from the M50 engine.
You should be fine, but I can't make you any guarantees. Run a few online searches. You're bound to find tons of useful info.
Good luck!
Old 08-29-2009, 07:59 PM   #11 (permalink)
Car: 1992 318i
ok cool, good info. this is what i love to hear... good useful info. but as far as bolting up,l it should work?
Old 08-29-2009, 09:04 PM   #12 (permalink)
drz
drz's Avatar
Car: zhp
Both the 200 and 250 bolt up to the 318's engine. My guess is that they'd both bolt up to the M50 as well. But that is what it is: only a guess.
Possible Donor? htp.bmw 3-Series (E21, E30) 1 07-13-2005 07:01 AM
E36 "donor" car???...looking for shell E36 m3kindaguy M-Series (M1, M3, M5, M6) 12 09-19-2004 06:24 AM
