What controls the windows to lower when opening/closing the door? - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 02-27-2007, 06:02 PM Thread Starter
agtur2001's Avatar
agtur2001 is an unknown quantity at this point
My 1994 325ic intermittenly decides NOT to lower the window about an inch when I open and close the driver/passenger door.
As you know, the windows normally go down about an inch and then go back up when the door is closed.
What do I need to replace to fix this issue? used:
Thanks!
agtur2001 is offline
post #2 of 8 (permalink) Old 03-01-2007, 12:15 PM Thread Starter
agtur2001's Avatar
Wow... no one has had this issue?
post #3 of 8 (permalink) Old 03-05-2007, 12:09 AM
Da Prophecy is on a distinguished road
The part you need is called a latch striker.
If you look at the door jam it is the part that the door latches to.
The latch striker has a button that is pressed when the door is closed causing the window to go up.
You can press the button with your finger to see its effects if you like.
Kyle
Da Prophecy is offline
post #4 of 8 (permalink) Old 08-22-2007, 04:09 PM Thread Starter
agtur2001's Avatar
Thank you... I will take a look at the Latch Striker for both doors since neither side goes down/up when you open/close the door.
post #5 of 8 (permalink) Old 08-23-2007, 01:49 PM
barry.croston is on a distinguished road
i think the post 96 e36 had the sriker on the b pillar but pre 96 cars have them in the door somewhere.
quite a common fault and i recently replaced one of mine
barry.croston is offline
post #6 of 8 (permalink) Old 08-23-2007, 02:01 PM Thread Starter
agtur2001's Avatar
Thanks... I will check the the door again since I couldn't find it. I guess I need to replace it for both doors since neither one opens/closes the window an inch when the doors are opened and closed.
post #7 of 8 (permalink) Old 08-28-2007, 08:05 AM
condor27596 is on a distinguished road
I have the 93, that sensor is not in the door striker.
It's in the door behind the panel up near where
the door lock thing comes out (lock post or whatever).
condor27596 is offline
post #8 of 8 (permalink) Old 09-03-2007, 01:38 AM
SGXander's Avatar
SGXander is on a distinguished road
Send a message via MSN to SGXander
be carefull if it is intermittent it could be a short my 318is just either takes ages to disarm or central lock (for example) or has intermittent power loss with any electronics when there is a bulb missing/ maintanance going on
SGXander is offline
Intermitient Operation Of Drivers Side Door Window mudilik 5-Series (E12,E28, E34, E39, E60) 1 08-18-2005 09:56 PM
Solution to Door Edge Seal Problem zulkhernain 5-Series (E12,E28, E34, E39, E60) 4 09-16-2004 09:24 PM
X5: 0-60 in 4.0 tcpgv 1,6,7,8 - Series and Mini Cooper 6 03-30-2004 02:51 AM
Power Windows studio945 3-Series (E46, E90) 4 01-18-2004 06:03 PM
Coupe door windows Chriso 3-Series (E36) 4 11-27-2003 06:08 AM
