...and has an awful lot of negative camber in the front and back. Is there anything that can be done to correct the front camber without dropping almost $400 on adjustable camber plates? I used the search, albeit quickly, and found only threads about using the plates. Basically, can I get some positive camber back on the cheap, like fixed plates that only correct it so much, etc. I had a camber issue on another car, and it was fixed by slotting the bolt holes so the top of the strut could be moved; maybe something like that...
__________________ Isaiah 53:5-7 He paid a debt he didn't owe because I owed a debt I couldn't pay.
I would just save and get camber plates(400 seems high for them) donno any other way to loose front camber
Btw is that you hugging a banjo?
1992 318i Coupe parts car
Problem is that I'll be using this car as a daily driver, don't want to lose a war pension on tires. I've fixed plates that are for adding negative camber, but none that are for taking it away
Guys, 5.72070K on TireRack which you guys are looking at are camber plates; TireRack just uses a generic image ... look on eibach.com if you don't believe me.
Camber bolts can not work on a e36 because of the way the strut mounts to the car ... you can add camber with longer bolts and washer but there is no way to take it away.
Please explain to me where you'd put longer bolts ans washers to add camber. I believe what you are saying, I'm just trying to get a better idea of precisely what you mean.
The bolt #3 and washer #4 in the picture are what you replace. The factory bolts (2 of them per side) are 20mm long. You'd need 25mm long bolts and 5mm worth of washers per bolt (depends on manufacturer of bolts but normally 4 washers).
Let's say you only want to shim it out a little bit: you put two washers between the strut and the spindle (and you put the other two where the factory #4 washer was); if you need all 4, then you put all 4 between the strut and spindle and use only one (the factory one) where the original was too.
Keep in mind though that you need 10.9 grade bolts and washers (which only some hardware stores sell): the bolts are M12x## (## being whatever length you need; factory is 20mm) and the washers are M12. The 10.9 (grade of steel) is normally on the head of the bolt. Do not use weaker (8.8 grade) bolts ... last thing you want is for one of them to snap (especially with the extended length) after you hit a pothole.
Most online parts sources sell "camber shim kits" and what have you; Google: e36 camber shims or something like that and you'll find plenty of stuff.
