Originally posted by jrhaile@May 11 2004, 02:08 AM
Also how much is a cat converter to fix and is it important to get it done asap or can I wait for a while? |
the bimmer cat is an expensive pussy - maybe 700 without labor...
ouch!
if it has gone bad, you might want to do it asap.... i believe having bad cats send wrong signals to your car's mainbrain that decides the air-fuel mixture and thus costing more gas and more often result in power loss....
can someone please call on cisco to explain this?
by the way,,, if its your cat, you must have at least your check engine light on... unless you got a busted fuse.
