Weird Noise... - BMW Forum - BimmerWerkz.com
Old 12-13-2004, 11:24 AM   #1 (permalink)
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240 Send a message via MSN to uiuc240
It's been cold here in Illinois lately, and when I start my car in the morning, I've been noticing a strange noise from what seems to be the *back* of the dash, near where the brake master cylinder would be on the firewall. It's this somewhat rhythmic humming noise, and it's quite noticeable. It seems to have no real pattern, as it just goes "brrrrrrrrrrrr...brrrrrrrr..brrrr......brrrrrrrrr. .." and so on. It goes away after the car is sufficiently warmed up (about halfway to work).
I've read something about a mono valve? Is this what I'm hearing? If so, is it functioning properly? Is the sound something I should just get used to? Is something about to break? What is the "mono valve" and what does it do? Can it be disabled? I don't really like the sound, and if I don't need it, I'd be inclined to take it out. Any help would be great. Thanks!
Eric
<img src='http://home.comcast.net/~eric_d_johnson/sig_pic.jpg' border='0' alt='user posted image' />
uiuc240 is offline   Reply With Quote
Old 12-13-2004, 12:11 PM   #2 (permalink)
agtur2001's Avatar
Car: 1994 325ic
agtur2001 is an unknown quantity at this point
Eric
[snapback]249093[/snapback]
agtur2001 is offline   Reply With Quote
Old 12-13-2004, 12:15 PM   #3 (permalink)
agtur2001's Avatar
Car: 1994 325ic
Eric
Hi Eric, Not sure if your NOISE is the same as MY NOISE problem.... but my noise was a Brr... cracking... static sound. In either case, I located the sound point of orgin on my car. (93 318is) It was coming from a tiny speaker under the dash between the steering wheel and brake/gas/clutch pedal. I removed the dash cover and figured out which wire to disconnect. Sound is now gone!
Good Luck!
Alex
Old 12-13-2004, 12:49 PM   #4 (permalink)
I remember reading about that...I think my sound is different. It's a humming sound, and I can actually feel it very slightly as it vibrates the pedals... still confused. Thanks though!
Eric
Weird Clicking Noise? KevinTS 3-Series (E36) 8 06-15-2005 06:07 PM
Weird Popping Noise 2000BMW323i 3-Series (E46, E90) 3 04-09-2005 08:18 AM
Turning Wheels Makes Weird Noise LivinFast67 3-Series (E36) 4 10-01-2004 07:34 PM
Weird Noise BlantonG13 3-Series (E36) 8 05-18-2004 03:43 PM
Weird clutch noise brosnan6 3-Series (E36) 3 04-25-2004 11:31 AM
