Originally posted by loftygoals+Jun 13 2005, 06:23 PM--><div class='quotetop'>QUOTE(loftygoals @ Jun 13 2005, 06:23 PM)</div><div class='quotemain'><!--QuoteBegin-KevinTS@Jun 13 2005, 02:10 PM After i put in my new m3 flywheel and clutch. [snapback]353210[/snapback] |
Did you install an OE dual mass flywheel or a single mass lightweight flywheel? A lightweight flywheel will chatter in neutral. The only fix is to get custom software to raise the idle speed. Typically the chatter magically disappears at 1100 RPMs. My personal fix is to always be in motion and WOT.
-bj
[snapback]353310[/snapback]
[/b][/quote]
No expert myself, but isn't a 1100 RPM idle really high? Isn't it normally like 500 RPM?
