Water pump removal - BMW Forum - BimmerWerkz.com
Old 02-20-2011, 05:41 PM   #1 (permalink)
ncktuley1's Avatar
Car: 92 318is
ncktuley1 is on a distinguished road
Exclamation Water pump removal
okay im pissed! im trying to get the lower timing case cover off my m42. so i have to pull out the water pump. in the manual it says to put 2 screws into the pump and that should pull it out. so i try it and it breaks the outside of the pump and the damn thing is stuck inside there and wont budge! what the hell am i supposed to do?
ncktuley1 is offline   Reply With Quote
Old 02-20-2011, 11:12 PM   #2 (permalink)
jmo69's Avatar
Car: 1998 328is 2003 325xi
jmo69 is on a distinguished road
PB Blaster and a dead blow hammer.
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline   Reply With Quote
Old 02-21-2011, 12:59 AM   #3 (permalink)
ncktuley1's Avatar
Car: 92 318is
peanut butter blaster? haha im kidding i just broke the damn thing out of it with a nice sized hammer. luckily i have two other pumps!
Old 03-07-2011, 08:22 AM   #4 (permalink)
GGH
Car: 1999 328i E36 conv't
GGH is on a distinguished road
You may have cocked the housing to much causing the breaking and getting it stuck. I did mine and the clearance is very small. So, tap lightly on the side that has the most space between the block and housing so there is equal space and screw out equally.You may have to use a screw driver to help,but use very carefully. GGH
GGH is offline   Reply With Quote
745i water pump/electric fan removal ryankjb 1,6,7,8 - Series and Mini Cooper 4 06-01-2010 05:16 AM
HELP ! 97 BMW 750 Water Pump Removal SoCal750iL 1,6,7,8 - Series and Mini Cooper 4 12-05-2009 10:56 PM
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
water pump. HELP! viali8 3-Series (E21, E30) 2 05-30-2004 04:50 PM
