water pump again - BMW Forum - BimmerWerkz.com
Old 01-25-2006, 06:13 PM   #1 (permalink)
bimmer3214's Avatar
bimmer3214 is on a distinguished road
water pump again
so about 4 or 5 months ago my water pump went out along with the radiator and all the other little parts that go along with it. now the noise it was making before it went out sound like some kind of whinning sound at idle and all rpms just not as loud. Like a belt problem ya know that weird sound. Well now im hearing that sound again maybe only 5000 miles later. am i in trouble and going to have to fork out 1000 dollars or more again. or do you think this is just some belt? its towards the middle of the engine just to the right and downwards. i think that is the place of the water pump but im not sure. what do you guys think.
bimmer3214 is offline   Reply With Quote
Old 01-25-2006, 09:12 PM   #2 (permalink)
cloaked95's Avatar
cloaked95 is an unknown quantity at this point
Do you have a 5 spd manual? I was just thinking that it might be the T/O bearing starting to go. That is usually a sign that the clutch disk,plate and T/o bearings might need replacement. Another possibility might be your alternator. Where is the temp gauge at?
cloaked95 is offline   Reply With Quote
Old 01-26-2006, 06:18 AM   #3 (permalink)
bimmer3214's Avatar
no its an auto, and do you mean the temp gauge in side my car or is there another one somewhere
Old 01-26-2006, 10:03 AM   #4 (permalink)
Red_Rocket's Avatar
Location: Coeur D' Alene, ID : Tuscaloosa, AL : Atlanta, GA
Car: BMW 325
Red_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really niceRed_Rocket is just really nice
Send a message via AIM to Red_Rocket
the one inside your car
Red_Rocket is offline   Reply With Quote
Old 01-26-2006, 10:45 AM   #5 (permalink)
bimmer3214's Avatar
if you mean what temp is it at its like right in the middle just like a couple milimeters to the right of the middle
Old 01-26-2006, 07:48 PM   #6 (permalink)
cloaked95's Avatar
I think thats normal. Mine was like that before and after i replaced the water pump. I hope you used a metal impeller type when the water pump was replaced. Id check the alternator .It has a bearing that might also fail. Even if you do a load check on the alt. sometimes that doesnt mean the alternator is good. Also, does the whinning volume increase when the steering wheel turns? If it does, try flushing the power steering fluid with fresh fluid. Just trying to eliminate the possibilities. hope this helps
Old 01-26-2006, 08:07 PM   #7 (permalink)
bimmer3214's Avatar
alright man thanks for all the advice ill begin this weekend
Old 01-26-2006, 08:41 PM   #8 (permalink)
GranitSilbur is on a distinguished road
Im 99% sure that its the belt tensioner. Same thing happened to me. Eventually the tensioner will fail and leave you stranded. I replaced both the tensioner and defelection pulley. Engine is so much quieter too... good luck
GranitSilbur is offline   Reply With Quote
Old 01-26-2006, 08:49 PM   #9 (permalink)
cloaked95's Avatar
Thats another possibility. Pretty good post for a first timer. Welcome to the Forum
Old 01-26-2006, 09:03 PM   #10 (permalink)
bimmer3214's Avatar
yea man welcome. and thanks for the info.
How To Stop The Water Pump KILOCHARLIE 3-Series (E36) 8 08-03-2005 07:09 AM
Water Pump rb26 1,6,7,8 - Series and Mini Cooper 1 06-12-2005 09:52 AM
Question On Water Pump Explosion Phil137 3-Series (E36) 5 09-23-2004 10:42 AM
Leaky Water pump or the Themostat Housing RedBeemer95 3-Series (E36) 12 08-21-2004 07:13 PM
water pump. HELP! viali8 3-Series (E21, E30) 2 05-30-2004 04:50 PM
