water pump??? - BMW Forum - BimmerWerkz.com
Old 04-16-2010, 10:27 AM   #1 (permalink)
bimmergrl99 is on a distinguished road
water pump???
i recently started noticing that my temp gauge has been running extremely high, but it is only when i am in park or at a stop as soon as i start driving it will go back down. a freind who also has a bimmer said it was the water pump. any ideas??? please help before i blow a head gasket!!!!
bimmergrl99 is offline   Reply With Quote
Old 04-16-2010, 10:34 AM   #2 (permalink)
How's the fan and its clutch?
Old 04-16-2010, 10:50 AM   #3 (permalink)
its an auto so it doesnt have a clutch but the fan from wat i can tell is fine
Old 04-16-2010, 11:40 AM   #4 (permalink)
I don't mean a clutch as in drive train; the fan is clutched on by a thermostat as needed. When the clutch system is worn, the fan can't run and you will heat up while standing.
Old 04-16-2010, 05:16 PM   #5 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Check both fans: the electric auxiliary fan (most likely the culprit) and the engine-driven viscous clutch fan. A very quick check for the aux fan is whether it comes on when you turn on the A/C (it should). The engine-driven fan should turn with some resistance if you try to spin it by hand (with the engine off!) -- if it spins freely, it needs to be replaced.
Turkey Fleet Bond Holder
water pump oted 1,6,7,8 - Series and Mini Cooper 2 08-30-2008 10:26 AM
Water Pump TeeUp 3-Series (E36) 23 11-26-2007 07:03 AM
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
Water Pump Blackstar 3-Series (E36) 3 04-25-2004 03:07 PM
