viscous fan removal help! - BMW Forum - BimmerWerkz.com
Old 07-17-2004, 08:39 PM   #1 (permalink)
AutoFan is an unknown quantity at this point
do you have to have that special narrow 32mm wrench to get the fan off?
isnt there another way, i cant get the thermostat housing off with the fan on.
im right in the middle of this so any quick help is aprreciated
AutoFan is offline   Reply With Quote
Old 07-17-2004, 08:50 PM   #2 (permalink)
Kevin325i's Avatar
No, you don't. I just used a cresent wrench it fit right in there.
Kevin
Kevin (President TBEA)
Old 07-17-2004, 09:04 PM   #3 (permalink)
yeah i have a wrench that fits on it but i cant get it to break loose the
pulleys just turn. ghead
Old 07-17-2004, 09:05 PM   #4 (permalink)
A 1 1/4" wrench filed up a bit at a time will do the trick (25MM to the inch for government work). I used this metod, I also filed the out side ot the wrench head down to give me a little more roo behind the fan blade. Nest trick is to hold the fan in place while whacking on the wrench, I use big vise grips to pinch the belt together while I whack that 32 MM nut.
Old 07-17-2004, 09:09 PM   #5 (permalink)
Kevin325i's Avatar
Put a vice grips on one of the pullies and onto something that won't move. That's what I had to do, I've also heard a 6mm allen wrench fits in between the thigns on the water pump, but I never tried that.
Fan Delete chico_kj_23 3-Series (E36) 5 02-04-2010 12:40 PM
New here. Question about what fan noise could be.. torre 325i 3-Series (E36) 3 10-09-2005 03:28 PM
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
How do you get the $#?!@ blower fan out of an E36? strubmw 3-Series (E36) 3 09-19-2005 06:13 PM
Help! Rear Bumper Cover Removal earthwormjim 3-Series (E36) 1 01-19-2005 04:37 PM
