vanos noise - BMW Forum - BimmerWerkz.com
Old 02-16-2006, 10:02 PM   #1 (permalink)
cabrit is on a distinguished road
vanos noise
when the car is running it makes a noise in the vanos area as if the chain is loose its kind of like a metal sound the car dont idle roughly the rpm needle is steady dont seem like i`m loosing power. do all of them make that noise or this is something i should be concerned with.
any help would be appreciated
cabrit is offline   Reply With Quote
Old 02-16-2006, 10:04 PM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Vanos does have a tendency to sound like marbles rattling around in a coffee can.
Lindsay fan club member.
Old 02-16-2006, 10:11 PM   #3 (permalink)
thats exactly what it sounds like
is this a good thing or bad thing
Old 02-16-2006, 10:30 PM   #4 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
This is obviously not good. If you can get the stuff get some BG Engine Quick clean. Add the can to the engine when the engine is at about 1/4 temp, then drive the car for 20-30 min. The more stop and go driving you do the better, this will move the VANOS through its range of movement a lot more than just staying at one steady speed on the freeway. After you are done driving the 20-30 min change the oil and refill with whatever 10-30 you like. We have fixed a few cars this way at the BMW shop I work at and saved our coustomers a lot of money since they didn't have to buy a complete VANOS unit.
My M50 Powered E30 Page
Old 02-16-2006, 11:53 PM   #5 (permalink)
thanx a lot where can i get BG engine clean
Old 02-17-2006, 06:20 PM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
I'm not sure if local auto parts stores have it or not but almost every repair shop I have worked in had it in stock so just call arround and see if they have a can. If you are in the Sacramento area you can come up to our shop, we have it on the shelf.
Old 02-19-2006, 12:30 AM   #7 (permalink)
dam unfrotunately i am in nyi checked pep boys so far nada the best they have is that restore engine additive
Old 02-19-2006, 03:10 PM   #8 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Engine Restore is nothing like the BG Quick Clean. Call arround to the local repair shops that is probably going to be your best bet.
Old 02-28-2006, 03:49 PM   #9 (permalink)
somebody told me i might also have to cahnge my water pump
i am hearing a whistle type coming out from the engine on acceleration could it be the water pump
Old 03-01-2006, 02:23 AM   #10 (permalink)
vwk
vwk is an unknown quantity at this point
It could be everything. There all pulleys, it's quite normal to replace them like every 15.000miles
Euro E36 M3 3.2 Rebuild Project
27 years
vwk is offline   Reply With Quote
Old 03-04-2006, 11:12 AM   #11 (permalink)
Car: 97 328is, 93 318is
thinair is on a distinguished road
Send a message via ICQ to thinair Send a message via MSN to thinair
I have the same issue. It could be a timing chain tensioner, or just a rattly VANOS. If you have 60k or more try getting a new tensioner installed. They're not that expensive.
Nelson Papel
1997 Madeira Violet 328is - Carbonio Intake, Racing Dynamics exhaust, fan delete, ASC delete, M50 intake manifold, M3 Cams, Eurospeed/AA software, 3.38LSD, M3 f&r brakes + MC, Bilstein PSS, Eibach swaybars, BBS RK 17x8" wheels, Toyo T1R (235/40R17) tires, Racing Dynamics K55 kit, full euro lighting, 4300k HID lows, etc..........
<a href='http://www3.sympatico.ca/thinairbikes/bmw.htm' target='_blank'>Click here for more info on my car</a>
thinair is offline   Reply With Quote
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
Ticking Noise From Engine Clint_M 3-Series (E36) 9 11-07-2004 11:02 AM
Vanos Noise SD325I 3-Series (E46, E90) 2 11-05-2004 11:34 PM
loud noise - including clicking tsinghbmw 3-Series (E36) 6 06-01-2004 02:25 PM
