Valve cover gasket question for newbie - BMW Forum - BimmerWerkz.com
Old 03-18-2009, 08:54 PM   #1 (permalink)
328ic98's Avatar
Car: 1998 BMW 328 Ic Cabriolet
328ic98 is on a distinguished road
So I will be putting back together the car - Do I need to put a bead of sealer around the entire perimeter of the gaskets, or just problematic areas? Many thanks!
328ic98 is offline   Reply With Quote
Old 03-18-2009, 09:12 PM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
The BMW factory manuals recommend adding some sealant to some leak-prone sections of the cylinder head. I chose to use Permatex High-Temp RTV, and it worked very well for sealing these areas. Specifically, the factory recommends adding sealant at the interface where the VANOS unit or front mounting timing chain cover meet (Figure 19 and Figure 20). They also recommend a small bit of sealant at the rear of the cover (Figure 21).
Pelican Technical Article: BMW Valve Cover Replacement
johnny,
Old 03-19-2009, 06:51 AM   #3 (permalink)
328ic98's Avatar
Thanks, Johnny- maybe I won't screw this up so bad now!
e34 valve cover gasket d3ity 5-Series (E12,E28, E34, E39, E60) 2 12-08-2010 07:37 PM
Question about Valve Cover Gasket ????? 325IConvertible 3-Series (E36) 8 11-20-2006 10:48 PM
Valve cover gasket replacement... e36surge 3-Series (E36) 3 11-15-2005 12:03 AM
do i need a new gasket for valve cover ? j123crx 3-Series (E21, E30) 3 10-30-2005 09:14 AM
Do I Need a New Valve Cover Gasket?! abemcclellan 3-Series (E36) 12 08-31-2004 12:41 PM
