Vaccuum Leak - BMW Forum - BimmerWerkz.com
Old 06-16-2004, 01:42 PM   #1 (permalink)
tico481's Avatar
tico481 is an unknown quantity at this point
Send a message via AIM to tico481 Send a message via MSN to tico481
How can I tell if my car has a vaccuum leak??
<u>1995 BMW 325is</u>
- //M3 Spoiler
- 15% Tinted Windows
- Front License Plate Delete
If I say something stupid, it's probably cause I'm ripped
tico481 is offline   Reply With Quote
Old 06-16-2004, 02:27 PM   #2 (permalink)
Speedy-325is's Avatar
Hissssing noises r a big clue
use a can of starter spay(carb cleaner works too) and MIST, dont hose down, the area u wish to test. for example if u want to check for craks in a vaccume hose, lightly spray the hose w/ur car running in idle. when u spray, step back and listen to the engine/RPM'a for a change/rise in sound. if the rpm's rise, u found ur problem. if no change, then keep searching.
the hose connections where the hose clamps begin to crack up sometimes, so there can be hard to find cracks after a while.
Good luck
Mark
Old 06-16-2004, 02:51 PM   #3 (permalink)
tico481's Avatar
I feel like an idiot asking this, but where is the vaccuum hose located?
- //M3 Spoiler
Old 06-16-2004, 06:02 PM   #4 (permalink)
thekid's Avatar
If you have a 318i then the hose behinde you engine up near the cowl piece has a tendancy to crack, also the hose going from your FAMS to your engine is also one that likes to crack. If they are cracked you should be able to see it, but you may have to check both sides of the hose. Also you may get an engine code from a vacum leak.
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Oil Leak htp.bmw 3-Series (E21, E30) 6 09-07-2005 12:15 AM
A Slight Leak mikester328 3-Series (E36) 1 01-06-2005 11:20 AM
Oil leak... Regnout 3-Series (E36) 21 11-07-2004 09:06 PM
faster leak when cold. dubumb 5-Series (E12,E28, E34, E39, E60) 12 02-02-2004 09:42 PM
