Originally posted by Tiz+Mar 29 2005, 06:09 PM--><div class='quotetop'>QUOTE(Tiz @ Mar 29 2005, 06:09 PM)</div><div class='quotemain'><!--QuoteBegin--pimpin328is-@Mar 28 2005, 07:43 PM what problems are you having because of that feature not working....
does it make it hard to open/close door? just wondering [snapback]320335[/snapback] |
It does make it a little harder to open and shut the door but surprisingly it still shuts and seals tight. I'm just worried its going to wear the seal down or mess the window up eventually. Also, you know how power remains to the windows even after you turn the car off until you open the door? I think, because of the door sensor not triggering, the power stays on constantly. I just had to replace the battery!
[snapback]321145[/snapback]
[/b][/quote]
is the little switch stuck?.......open your door and push the striker switch in and out.... the window should go up/down.......
you may just want to replace them... I've replaced both of mine...
... did either window jump up and down at random while you were driving at any point?
