ungo remote lock/unlock/start - BMW Forum - BimmerWerkz.com
Old 08-22-2009, 12:56 PM   #1 (permalink)
Car: 1994 BMW 325i
jordanmg is on a distinguished road
So I've got a 94 325i. It has the remote with it, but only the remote start works, the lock and unlock buttons don't.
Any ideas on how to reset it or where I can find a manual on "Ungo" remotes? Or maybe the locks are broken, how could I figure it out?
jordanmg is offline   Reply With Quote
Old 08-22-2009, 02:07 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
factory remote or aftermarket?????
Old 08-22-2009, 03:26 PM   #3 (permalink)
Car: 1994 BMW 325i
its aftermarket. the brand is called UNGO
Old 08-22-2009, 03:32 PM   #4 (permalink)
Cool
WARNING! aftermarket anti-theft alarms NEVER worked with BMW circuits.
That's a fact. If you have one, take my advise and remove it -it will cause you lotsa trouble down the road.
Old 08-22-2009, 08:18 PM   #5 (permalink)
Car: 1994 BMW 325i
craaap. What kind of problems do they cause? How much do the stock remotes cost? What would I have to do to remove the aftermarket stuff and put in the old stuff?
Old 08-22-2009, 09:28 PM   #6 (permalink)
Post
In Basics:
keyless entry works by frequencies. BMW has it's frequency; vis-a-vis the frequency that the aftermaket item uses.
Consider this: even if it is plug-n-play and you can successfully get teh aftermarket unit to operate. You are in effect operating 1 system with 2 separate frequencies. If you are lucky, It might work for a period of time.... BUT, it also throws your system in a (what we call) a 'loop". Over time the system will be confused as to what frequency to recognize and then, the system goes "GAGAGAGAGA....." , and, problems begin.
Then, electronically: whenever u introduce aftermarket stuff in the car(including plug-n-play stuff); you are in effect disrupting the balance of the original system. Static and kinetic charges are introduced... that inteferes with the way electronic components perform, and these in time contribute to the deterioration of 1 part or another in a system. That translates to..... Breakdown!
To answer ur Q: re-stock remotes
Bring your VIN & proof of ownership to a BMW dealer. They can decode whether your car has remote + anti-theft OR remote entry only(these are 2 separate items depending on year and model).
Then you can go from there :-) Parts of course need not be brand new. U can source from eBay or recycle shops...
Remote no longer unlock truck resq45hero 3-Series (E36) 11 01-04-2009 06:19 AM
Help. Doors Will Lock, But Not Unlock zenok 3-Series (E46, E90) 9 03-27-2006 02:42 PM
Lock, Unlock emericadna7 3-Series (E21, E30) 5 11-22-2004 05:06 PM
Remote Lock/Unlock Arm/Disarm..... bimmerboy328i 3-Series (E36) 5 05-30-2004 05:58 PM
Help. Doors Will Lock, But Not Unlock leogane 3-Series (E21, E30) 0 12-31-1969 07:00 PM
