Underdrive Pulley Instal Issue - BMW Forum - BimmerWerkz.com
Old 05-18-2005, 02:11 PM   #1 (permalink)
Rooz's Avatar
Car: 2003 M5
OK, as some of you ,might know, my underdrive pulleys finally arrived from UUC. So today at the shop, I attended to put them on. I Followed the instructions that UUC gave pretty well,
1. I diconnected the battery,
2. Removed the alternator-cooling duct,
3. Removed fan nut and left it in shround,
4. Removed underbody covers,
5. Loosend all the bolts from water pump and power steering pulleys,
NOW here is where things started to go wrong
6. I attempted to loosen//remove the Air conditioner belt tensioner, but I noticed that it had a slight crack and as I removed it it broke , so I need a new one of those now. But What I cannot find is where is the Alternator belt tensioner at???? And how would I go to loosen it so I can take alternator belt off?
I would truly apreciate it if someone could help me out on this, even better if someone could give me a diy on how to I guess replace the belts...
VIEW MOD LIST & PICS
Originally Posted by Gregg
Rooz is offline   Reply With Quote
Old 05-19-2005, 12:58 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
ok a few things here, 1. the ac belt , just pick it up from anywhere.
2. the proper way of taking off the serpentine belt (there is no single belt for each accessory) the tension pully is shown in the pic below, pretty much right behind my hand, you need to pop the dust cover off of that and use the proper socket and slack the tensioner (i think its clockwise but dont quote me its been a while since ive done it) then remove the belt.
[attachmentid=22007]
ill look for my DIY on belts if i get a bit of time
Old 05-19-2005, 12:07 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Yes it is cloclwise... changed mine before... twice... dust cover... and socket get her done... its not all that hard once you understand it... that pully is on a oval type mount if that helps... dont take it all the way off... meaning dont take the pully all the way off... it bolts through your alternator but takes forever to get out... and a pain in the ass to reinstall... due to the oval alinement that has to be done...
Any ways, Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 05-19-2005, 02:26 PM   #4 (permalink)
Rooz's Avatar
Car: 2003 M5
Well, the pulleys are finally on. ANd I really do feel a diff, specially in low-end torque which is what I was shooting for and the engine seems to sound "beastier" and also sicne am putting less pressure on the gas pedal, am aussuming my mpg will go up So, yes I definetly suggest this mod to anyone who wants to do it and has some mechanical knowldge, it took a friend and I about 2.5 hours to do the all thing with tools and a lift.
Oh and thkx a lot for the help, but Furious, that engoine is different from mine
Old 05-19-2005, 03:33 PM   #5 (permalink)
Shudogg's Avatar
Shudogg is an unknown quantity at this point
will those pullies fit on 318's
there is no where ive found that has em' specially for 318's
i skipped looking for a 318 clutch and flywheel and got a lightened m3 (8.5lbs) and a Clutchmasters m3 clutch and throw-out bearing, so, this makes me think that if that fit, then why wouldnt these???
<span style='color:red'>
CLASSIFIED</span>
<span style='color:blue'><a href='http://www.whiplashdvd.com' target='_blank'>WHIPLASHDVD.COM</a></span>
Shudogg is offline   Reply With Quote
Old 05-19-2005, 03:50 PM   #6 (permalink)
Rooz's Avatar
Car: 2003 M5
CHeck UUC out
Old 05-20-2005, 02:33 PM   #7 (permalink)
Shudogg's Avatar
UUC only makes em' for the e36 323 and up....SO - what im askin is will they fit a 318i?
ive put an m3 clutch and flywheel on my car so what would it take?
CLASSIFIED</span>
Old 05-22-2005, 11:09 AM   #8 (permalink)
Rooz's Avatar
Car: 2003 M5
I don't know how much the 318's engine differs from mine, so I couldn't really tell you if the pullies would fit a 318.
Old 05-22-2005, 11:13 AM   #9 (permalink)
Shudogg's Avatar
ya i figured that no one had expirience with theirs and a 318, im just gonna get the UUC ones and hope they work
CLASSIFIED</span>
Old 05-23-2005, 11:26 AM   #10 (permalink)
k2c69n's Avatar
k2c69n is an unknown quantity at this point
would i be able to change them without using a lift, just driving the front up on blocks.
*If your not living on the edge your taking up too much space*
'98 328is
k2c69n is offline   Reply With Quote
Old 05-23-2005, 06:24 PM   #11 (permalink)
Rooz's Avatar
Car: 2003 M5
Lift REALLY hlps, but yes, u can do them without one
Old 05-23-2005, 06:35 PM   #12 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
I think I will do this mod once I have $$. Hope it works well on automatic transmission cars.
What does the Idle Pulley Tensioner look like (see pics)? Delmarco 3-Series (E36) 9 10-02-2005 09:00 AM
Turner Pulley Kit--- Help NeverLeaned 3-Series (E36) 2 10-24-2004 06:28 PM
Underdrive Crank Pulley M3Daemon 3-Series (E36) 9 04-06-2004 07:58 PM
UUC Motorwerks Pulley Kit PoloBlue67 Classifieds Sell & Buy 0 03-13-2004 07:22 PM
