Has anyone underdriven the crank pulley? Do I need a shorter belt if I do it? I know there are underdrive pulley kits available for particular accessories but which option is better (crank or accessories)? Or could I do both?
Underdrive pulley kits ussually give you new pulleys and belts that will work, but i suppose it would be possible to buy your own parts.
Either way I think most underdrive pulley kits make a note that your cars idle won't be able to charge the battery properly. Which doesn't sound like much of a problem unless your constantly in traffic. Sorry i didn't have more info.
Underdrive pulleys rotate less tha the stock pulleys allowing your engine to do less work in turn giving you more power. Check understeer.com for some advice on the pulleys, the say underdriving everything except the altenator is ok. You can do the altenator but it doesn't do much for engine power and charges slower.
__________________ PRESIDENT OF THE OVER 10 YEARS OLD AND UNDER 100K MILES CLUB
1993 325i 5spd
Benfer Performance Intake
M-tech Pedals and Shiftknob
Bavarian Auto Floor Mats
Wheelskin Steering Wheel Cover
Panasonic Head Unit
Euro Projector Lights w/ black Housing
Black Housing Clear Corners
Dinan Chip
MORE TO COME!!
Also have you heard of the fan delete mod? Its on the same lines as underdriving.
1993 325i 5spd
Panasonic Head Unit
Dinan Chip
MORE TO COME!!
Originally posted by 325i_daemon@Apr 5 2004, 11:01 AM I was thinking about the fan delete mod but it's extremely hot where I live and I don't want to take chances during the summer.
Why not install an electric fan? Mount a switch inside to flip on when it's a hot day, or I imagine it would be possible to rig it up to a thermostat. I haven't seen any kits for BMWs though.
Anyone else with more info?
When doing the fan delete mod you actually change the fan switch to one that kicks on your auxillary fan at a lower temperature along with the new thermostat. You can upgrade your fan to one with a higher cfm rating, but i'm not sure what the stock cfm is. Where do you live that it is so hot. I live in florida and plan to do this mod this summer. If i do see my car getting too hot its not that big of a deal to throw the fan back on.
1993 325i 5spd
Panasonic Head Unit
Dinan Chip
MORE TO COME!!
Originally posted by Andrewsd1985@Apr 6 2004, 07:37 AM When doing the fan delete mod you actually change the fan switch to one that kicks on your auxillary fan at a lower temperature along with the new thermostat. You can upgrade your fan to one with a higher cfm rating, but i'm not sure what the stock cfm is. Where do you live that it is so hot. I live in florida and plan to do this mod this summer. If i do see my car getting too hot its not that big of a deal to throw the fan back on.
I live in Mobile which is about 20miles from the Florida state line. Keep me posted on how the fan delete mod works out; I might do it after all...
