Hello all,
Yes per usual another unsure user who doesnt know the correct trye size to use for the wheels hes purchased.
I have a set of Azev A types at 17" x 8, I cant be sure if i can put 245/45 tyres on the back and 235/45 on the front or if i shud put 235/40 all round or 225/45 all round please someone give me the correct profile to use so i can carry on motoring!
The car is a 320i se 1996 saloon. suspension and springs etc etc are all standard.
Many Thanks
Sol
235 all round is what i have, i get lots of pulling and road noise when the tires wear low but it well made up for in corners. more tread done means more traction , which can lead to more hair raising cornering.
Thanks everyone who gave me ideas i went for 225/45's all round in the end to be on the safe side.
Very happy with the out come.
i know its in the wrong post but how can i upload pics in an album? as atm when i pull down the menu part it doesnt allow me to upload or delete an album etc. any info appreciated.
Originally posted by Furious@Dec 10 2004, 02:59 PM 235 all round is what i have, i get lots of pulling and road noise when the tires wear low but it well made up for in corners. more tread done means more traction , which can lead to more hair raising cornering.
MAN!!! i was hoping to find what profile to use for 17"s. If i could choose, id take 40, but i also see many ppl with 45. so which is it? obviously your rolling diameter changes according to your tire profile. i want my speedo to be accurate. Help??
__________________ <img src='http://members.optusnet.com.au/drpsi/sig.gif' border='0' alt='user posted image' />
South Africa - Home to the 3 series, and myself
i personally would say the 45 series, its a more comfortable ride than the 40's, and the performance is pretty much the same. and the only way to get an accurate speed reading is to slap your tires on and take to a dealer or specialty shop to re-adjust it. sux huh... ghead
i know this is off topic, but i might be getting rims soon, and the last tires i had on my previous car were yoko paradas...they were , anyone know anything about the paradas spec 2. im pretty sure its the same, just wanna see if anyone has it on they car and how it rides on a e36.
I beleive the correct size (certainly here) would be 225/45x17....but if you want your speedo to read correctly bearing in mind that all speedos read high by a small margin, go for slightly larger tyres to "correct" the OEM speedo error.
Either 225/50 or 235/45 should be about right. My speedo always reads 2 mph fast regardless of speed. I will be changing to 225/60x15 for winter use and 225/50x17 for summer.
Originally posted by Silencer@Mar 1 2005, 02:55 AM MAN!!! i was hoping to find what profile to use for 17"s. If i could choose, id take 40, but i also see many ppl with 45. so which is it? obviously your rolling diameter changes according to your tire profile. i want my speedo to be accurate. Help??
[snapback]301593[/snapback]
Go to www.miata.net/garage/tirecalc.html, (I know, a Miata site, but good info). You can type in different tire sizes and get the difference in diameter, circumference, percentage of change in speedo reading.
__________________ 1995 325I, window tint, K&N, debaffled airbox, BMW #104 wheels, Nighthawk low beams, smoked side markers, smoked corners, smoked taillights, M3 stlye heated mirrors, various interior bits, Bosal cat-back.
I know your speedo can be out after changing wheels, but dosn't it only make it a few seconds out? IF THAT! I mean your not going to be doing 50 outside when your speedo reads 30.
Anyway, I'd go for 225/40/17's, thats what I got, but they struggle to go under the rear arches without them rolled. Can hear them rubbing every now and again.
Originally posted by 2ndclasscitizen@Mar 1 2005, 05:18 PM I know your speedo can be out after changing wheels, but dosn't it only make it a few seconds out? IF THAT! I mean your not going to be doing 50 outside when your speedo reads 30.
[snapback]301720[/snapback]
Your right, it will only make a few MPH difference usually if you don't go too wild.
But as the speedo is only out by a few MPH and you have to go wider bigger to get the difference....why not?
I am suprised your tyres rub at that size, they should'nt if your within offset specs, have you lowered your suspension? (silly question eh? )
