Turn Signal Problem, stuck on, not blinking. - BMW Forum - BimmerWerkz.com
Old 10-26-2005, 10:07 AM   #1 (permalink)
jek1955 is an unknown quantity at this point
Send a message via MSN to jek1955
My passenger side turn signal is experiencing intermitant problems. While driving and using the signal sometimes it works fine, other time it starts out blinking and then stays on and at other times it starts in the on, non-blinking. Sometimes the light does not blink but remains on. When the car is turned of it remains lit. When the car is off nothing I do gets the light to go off. I must turn on the car and play with handle, tapping it, going back and forth between driver and passenger side etc... It also seems to happen more frequently when it the temperature is warmer. When it is stuck on it doesn't matter where the handle is, is in the middle, no turn, left or right postion.
jek1955 is offline   Reply With Quote
Old 10-26-2005, 09:50 PM   #2 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
have you checked things like your bulb connections or anything?
Old 10-27-2005, 06:48 AM   #3 (permalink)
No, I haven't checked bulb connections. I'm assuming it's either the device that controls the blinking or more likely something in the steering column.
HELP! Turn Signal not working??? kraze0g 3-Series (E36) 7 06-22-2004 12:39 PM
Turn Signal Regulator eclypser 3-Series (E36) 1 09-04-2003 02:30 PM
97 328i Turn Signal Relay dhruvm 3-Series (E36) 0 09-02-2003 04:18 PM
