Turn Signal Light - BMW Forum - BimmerWerkz.com
Old 08-08-2005, 05:19 PM   #1 (permalink)
mfitz4655 is an unknown quantity at this point
I just purchased a 1994 318 and the turn signals work fine except the right side indicator light in the dash by the tach doesn't blink to indicate that they are on.
I see some screws along the upper part of the clear window covering the lights. Is that how I access the lights?
mfitz4655 is offline   Reply With Quote
Old 08-08-2005, 06:11 PM   #2 (permalink)
if it is like my E30 it os not fun. Lower under dash panel remove, steering column surround remove, reach under and behind insrument cluster and remove two circular thumb screws, remove panel below instrument cluster, remove screws behind that panel, remove the two screws at top of cluster, then tilt her forward to acees electrcial connector releases.
Old 08-08-2005, 07:27 PM   #3 (permalink)
[snapback]368273[/snapback]
Thanks for the quick help. I'll try that tomorrow.
Old 08-09-2005, 12:04 AM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
relax.. i'll get a diy... hold on a sec
-SOLD..
R.I.P Fast 6
Old 08-09-2005, 12:07 AM   #5 (permalink)
Power Shifting
http://mysite.freeserve.com/bimmers/clusterbulbs.htm
there ya go!
-SOLD..
R.I.P Fast 6
Old 08-09-2005, 12:47 AM   #6 (permalink)
jimwww's Avatar
Car: Sold my 318is
jimwww is an unknown quantity at this point
Send a message via ICQ to jimwww
Half of my dash is dark.. one of the red ones is out.
By the way that link did not work above..
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the
Sold my 1995 BMW 318is 5spd Boston Green
<a href='http://www.jimwww.com' target='_blank'>My Webpage</a>
<a href='http://www.jimwww.com/bmw/' target='_blank'>My Pics</a>
*jimwww is a Professional Photographer, Film maker and Webmaster.
jimwww is offline   Reply With Quote
Old 08-09-2005, 01:20 PM   #7 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
Crusin', that sig is way sick dude.
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
Old 08-11-2005, 05:01 PM   #8 (permalink)
nathan56989 is an unknown quantity at this point
removed the air bag from the steering wheel (with battery disconnected) it a t25 or a t30 torxuse a driver. they are really tight so a pair of vise grips may have to be added to the driver. unplug the air bag. get it away from you set it face up on top of a table. then remove the steerign wheel bolt (16mm)
dont remove the wheel yet. mar the splines on the center of the wheel that way it goes back on in the same place.
then pull the wheel gently off don't pull hard because you'll unwind you slip ring not good by the way. once the wheel is off the splines rotate it down and set it on your legs. (don't let it hang)
then remove the t20 or t25 torx on the top of the cluster. and pull it out. the bulbs are the little black, tan, and green thing on the back.
nathan56989 is offline   Reply With Quote
Turn Signal Problem, stuck on, not blinking. jek1955 3-Series (E36) 2 10-27-2005 06:48 AM
Turn Light Signal Switch Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 0 08-12-2005 11:24 AM
Turn Signal And Back Light Issues bmwbob 3-Series (E21, E30) 0 02-15-2005 03:49 PM
Turn signal light bulb Blackdog 3-Series (E46, E90) 14 04-05-2004 12:22 PM
