Turbo Charge Kit 318i - BMW Forum - BimmerWerkz.com
Old 05-30-2004, 12:22 AM   #1 (permalink)
Cheeks318i is an unknown quantity at this point
I'm wondering if any one has any information on turbo charger kits for a 318i 5-speed. If I can find a kit i'd surely purchase it because I'm looking for more HP for my car. Thanks
Cheeks318i is offline   Reply With Quote
Old 05-30-2004, 02:24 AM   #2 (permalink)
Defector
El Presidente's Avatar
For FI the Downing Atlanta kit is by far the best. 220 HP, kit is 3k-something.
Old 05-30-2004, 03:02 AM   #3 (permalink)
brien4787's Avatar
brien4787 is an unknown quantity at this point
Send a message via AIM to brien4787
is it even worth it? will the car be able to handle the turbo over time? wont you need to keep replacing crap?
brien4787 is offline   Reply With Quote
Old 05-30-2004, 03:05 AM   #4 (permalink)
Defector
Unless the engine is low milage (Anything over 50s questionable, 75 tops), it will need to be rebuilt to assure quality performance anyway. Ergo, you won;t have to replace much crap continually.
Old 05-30-2004, 03:52 AM   #5 (permalink)
Super Moderator
dutchbmw's Avatar
......look before you leap.....
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 05-30-2004, 07:39 AM   #6 (permalink)
CiscoKid's Avatar
it will add a nice boost to your performance.... you will most likely need a new clutch and flywheel too
Old 05-31-2004, 02:39 AM   #7 (permalink)
Defector
You wouldn't need either of those right away, but you may burn the clutch from all the launches you'd be doing.
Old 05-31-2004, 04:35 AM   #8 (permalink)
Super Moderator
dutchbmw's Avatar
http://www.aatuning.com/main.cfm
http://www.activeautowerke.com/turbo/OBDI-...-STG2-Turbo.asp
http://dinancars.com
http://www.downingatlanta.com/
http://www.esstuning.com/
http://www.sharked.com/catalog.html
http://www.mosselmanturbo.com/index2.htm
http://www.turbo-kits.com/325_turbo_kits.html
http://www.mechtech-ms.com/indexcatalog.html
http://www.prostreetonline.com/pso/pages/d...ductsku=BE3625X
Here you can find turbo charger and supercharger kits.
Good luck, keep us informed!
BMW '96 M3 (SOLD)
Old 05-31-2004, 10:17 AM   #9 (permalink)
The most popular turbo kit (and the only reputable one I'm aware of) for the 318 is the Mossleman turbo kit. It's a garett turbocharger. I have friends who have this kit installed. I'd say price ranges from anywhere around $4000-$8000USD depending on where you buy the kit. Franky, I don't think the turbocharging is worth it. It's unreliable and the results aren't too impressive. On a chassis dyno my friend got 150RWHP on his ti (M44) which isn't that impressive. It's about a 30HP gain over stock (at the crank).
I'd go for the DA supercharger. It's a lot more reliable and it runs at relatively low boost 6-7psi. I have another friend who has this kit installed on his ti and it produces a nice 175RWHP (chassis dyno'd), that's about 60-80HP more than stock which is very impressive. I think you'll have no problems keeping up to stock 328's with this kit installed. It'll run you around $3000+ USD for a new kit. The only thing you would ever need to replace is the S/C belt. Make sure your engine has good compression before installing one, otherwise you should do an engine rebuild before the install.
I would upgrade the clutch kit to handle the increase in power. However, I make it a rule to always upgrade the suspension and brakes of the car before adding more power. Always make sure the handling and braking of the car outperforms the power of the car. That way, you're always in control.
Bry
Turbo 318i? mrfunk 3-Series (E36) 19 09-06-2005 08:52 PM
Super Charge Or Turbo NyteRyda 3-Series (E36) 7 11-14-2004 10:20 PM
turbo charging a 318i savo 3-Series (E21, E30) 1 03-26-2004 11:50 AM
