trying to figure out engine noise - BMW Forum - BimmerWerkz.com
Old 09-14-2010, 10:11 PM   #1 (permalink)
0517murphy is on a distinguished road
97 318i loud squealing sound from engine took belts off without change to sound. I'm not too schooled on 4cyl motors ,trying to eliminate what it's not before starting work hope someone can help.....witeshark had some great input ,looking for as many ideas as possible before I start. thank you....p.s. noise came all at once....
0517murphy is offline   Reply With Quote
Old 09-15-2010, 09:21 PM   #2 (permalink)
please help.... what could the engine noise be i don't think it's alt-water pump- starter -air comp because with out belts sounds like bad bearing but where? thank you for your comments in advance.....
Old 09-16-2010, 11:04 PM   #3 (permalink)
theluis's Avatar
Car: 1995 BMW 325i 5 Speed
theluis is on a distinguished road
theres two things u didnt mention there power streering pump and the idler pulley? (not sure if the 318s have one) and the tensioner.
the squeeking could be due to a bad tensioner
theluis is offline   Reply With Quote
Old 09-17-2010, 03:35 PM   #4 (permalink)
thank's for the reply theluis I was thinking the same thing at first until I removed both belts but the noise didn't go away, now I'm just confused... I'm thinking it may be in the timing but the engine still runs without skipping or backfiring .....need help bad!!!!
Old 09-18-2010, 04:45 PM   #5 (permalink)
theluis's Avatar
ok im starting to think tranny now is it automatic or manual?
if it is a manual then the clutch maybe slipping a little??
Another thing u can check is loose things u may have in the engine bay that may be shaking and making the squeeking noise
Old 09-18-2010, 04:54 PM   #6 (permalink)
thank you theluis it's a auto the noise is more like a loud grinding bearing not just a squeak .... does anyone know if the timing gears have bearings. 97 4cyl.
Old 09-18-2010, 05:05 PM   #7 (permalink)
theluis's Avatar
on the timing belt? (is it a belt?) if it is then there should be at least one tensioner as a rule of thumb. if they are chains which i think they are then probably does not have to do with timing...
Grinding from where does it sound internal? to check if it sounds internal open up the oil fill cap and listen in there...
Old 09-18-2010, 06:02 PM   #8 (permalink)
theluis tried to listen with the oil cap off really couldn't tell much .... sounds internal to me but for the life of me i can't seem to tell where .......
Old 09-18-2010, 06:05 PM   #9 (permalink)
theluis's Avatar
hahaha its ok... grinding can never be good... if its internal then your probalbly lookin at rod bearings or main bearings... =(
Old 09-18-2010, 06:09 PM   #10 (permalink)
theluis's Avatar
is there oil in the engine???!!!
Old 09-18-2010, 06:36 PM   #11 (permalink)
yea oil in engine first thing i checked....hahaha......thank you for your info guess i'm going to start tearing down in the near future hate to start without being sure what i'm looking for but it looks like where i'm heading
Old 09-18-2010, 09:59 PM   #12 (permalink)
theluis's Avatar
yea i have no clue wat else it would be... sorry and good luck
E39 Weird engine noise/vibration ? What could it be? (ENGINE VIDEO) 528i_tourer 5-Series (E12,E28, E34, E39, E60) 12 03-04-2009 11:59 AM
Can't figure out this suspension noise!@ Blackcatecho 5-Series (E12,E28, E34, E39, E60) 3 09-20-2008 08:47 PM
Cannot Figure It Out. Whirling Noise italiano 5-Series (E12,E28, E34, E39, E60) 3 07-02-2007 09:13 PM
Cant Figure Out How To Check My Engine Codes? streetdreams 3-Series (E36) 6 12-07-2004 01:51 PM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
