Trouble installing OEM Springs - BMW Forum - BimmerWerkz.com
Old 11-30-2009, 01:10 AM   #1 (permalink)
sberfield is on a distinguished road
Hi Guys,
Just started working on a 94 325i for my kid. The guy before me had the front lowered some and I want to get it back up to normal height given the cruddy roads around here.
Following the instructions in the 101 Performance Projects for your BMW book, I took the left front strut off, compressed the spring, popped it apart and put the OEM spring on. The trouble I have is that now the overall assembly is app. 3" longer than before and I can no longer get it to line up properly for re-mounting it.
I can get the control arm to drop some with my body weight, but not enought to get the strut into place.
Am I doing something really boneheadedly wrong and/or do I need to do more disassembly of the suspension to make this work?
sberfield is offline   Reply With Quote
Old 11-30-2009, 01:21 AM   #2 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
are there any other aftermarket parts in the suspension?
carguy13 is offline   Reply With Quote
Old 11-30-2009, 05:49 PM   #3 (permalink)
Nope
As far as I can tell, no aftermarket parts except the springs.
Old 11-30-2009, 08:37 PM   #4 (permalink)
W00T
Numark318i's Avatar
I had this issue with my 318 when i removed the assembly and replaced it with OEM springs.
You have to reinstall them with the spring compressors still on. Atleast that's how i got it to work. If you think about it when the suspension is fully extended there should still be some spring left. You shouldnt have to compress too much, but just a little.
Old 12-01-2009, 02:55 AM   #5 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
what kind of spring compressor are you using?
if it's the professional wall mounted one...you're going to have some trouble.
hopefully it's one of those little one's you can rent from Kragen or Pepboys.
besides oem coil springs are their others? lezbiian sweetz 3-Series (E36) 11 10-07-2008 10:13 PM
Installing lowering springs..... ?? sweetsilver 3-Series (E46, E90) 2 11-10-2007 12:22 AM
Where to order OEM rear springs? xaznxeclipsex 3-Series (E46, E90) 6 06-01-2007 10:28 PM
Trouble Installing An Amp (from Argentina) Helppp Pit_69 Audio and Electronics 3 05-20-2005 10:56 PM
Having Trouble Installing Keyless Entry BUSTaMOVE 3-Series (E36) 6 11-21-2004 06:44 PM
